Serial transceiver txoutclk is not being generated
I've designed the TX only SDI design for ZCU102 from ZCU106 12G-SDI pass through example design.
Modified the example design as required for TX only design.
The serial transceiver reference clock is given from the FMC card, which has a 148.5 Mhz  clk oscillator (default clk out).
I am not able to get the txoutclk from the GT core.  I've double verified my reference clk and transceiver constraints on the .xdc file.
Vinay
Vinay Shenoy
Tags (2)
Re: Serial transceiver txoutclk is not being generated
Hi @vinay_shenoy,
How are you checking the TXOUTCLOCK?
Could you make sure the GT is not held in reset?
Did you check the configuration (MGTREFCLK selection?).
Florent
I suspect a problem with the SDI GT in the design. Adding the GT signals to ILA for debug. Will update you
Vinay
Vinay Shenoy
@vinay_shenoy
From the last email from your SR, you were able to get TX and RX RESETDONE. Is txoutclk still not being generated?
Hi @vinay_shenoy
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
Hi @florentw @xud
I am away from this debugging for sometime now. Surely I'll update the findings and observations.
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
Any update on this?
Florent
