Newbie japa
Solution for DSI to HDMI and HDMI to DSI converter
I need a solution for the following flow:
Processor Output DSI 8 Lane
=>  (4096x2160@30Hz)
FPGA Input DSI 8 Lane
=>  (4096x2160@30Hz)
FPGA Block DSI to internal Format
=>  (4096x2160@30Hz)
FPGA block: Doubling the Frames
=>  (4096x2160@60Hz)
FPGA block: internal format to HDMI 2.0
=> (4096x2160@60Hz)
FPGA Output HDMI 2.0
=> (4096x2160@60Hz)
Prozessing Chip Input HDMI 2.0
=> (4096x2160@60Hz)
Prozessing Chip Output HDMI 2.0
=> (4096x2160@60Hz)
=>  (4096x2160@60Hz)
FPGA Block HDMI to internal Format
=>  (4096x2160@60Hz)
FPGA block: internal format to DSI 8 Lanes
=> (4096x2160@60Hz)
FPGA Output DSI 8 Lanes
=> Display (4096x2160@60Hz)
I saw that there are solutions for HDMI 2.2 Receive and Transmit.
The business case allows only FPGA costs of a maximum of 150 USD for 10k pieces. So is there a possibility to fit this solution into a Artix-7 device.
Re: Solution for DSI to HDMI and HDMI to DSI converter
Hi @japa,
You should talk to you FAE or Authorized distributor about this.
However, you won't be able to do 4K HDMI with Artix-7. You will need a K7 fabric. But it should be possible
