Streaming with Gstreamer
I am trying to stream out a 4k@30Hz H264 encoded video through my ZCU104 ethernet port. I am using the below pipeline:
gst-launch-1.0 filesrc location = bbb_sunflower_2160p_30fps_normal_avc.mp4 ! qtdemux ! video/x-h264 ! rtph264pay  ! udpsink host=192.168.10.153 port=9001
It doesnt cause any errors as I can see from TeraTerm.
I want to watch this stream with VLC.
I click on Media -> Open Network Stream...
Then I set the following:
Then I click the play button. But nothing happens. I cant watch the stream.
Is there anyone that can help me, please?
Tags (2)
Observer chlee.tw
Re: Streaming with Gstreamer
Hi @yildiz.bilgin :
1. Please add h264parse to insert SPS/PPS in every IDR frame.
gst-launch-1.0 filesrc location = bbb_sunflower_2160p_30fps_normal_avc.mp4 ! qtdemux ! h264parse config-interval=-1 ! rtph264pay  ! udpsink host=192.168.10.153 port=9001
 2. you can use TS@RTP
gst-launch-1.0 filesrc location = bbb_sunflower_2160p_30fps_normal_avc.mp4 ! qtdemux ! h264parse config-interval=-1 ! mpegtsmux ! rtpmp2tpay ! udpsink host=192.168.10.153 port=9001 sync=true
you can use VLC to open rtp:@:9001
Mentor watari
Mentor
Hi @yildiz.bilgin
Would you change networkt URL from "udp://@192.168.10.153:9001" to "udp://@:9001" on VLC ?
Best regards,
Hello @watari ,
I have tried it. Still doesnt work...
Mentor watari
Mentor
Hi @yildiz.bilgin
Would you share your source and sink host's IP address or network diagram ?
Best regards,
Hello @watari
This is my ZCU104 board IP address:
And this is my pc ip:
Best regards
Observer chlee.tw
Hi @yildiz.bilgin :
For H264@RTP, you should create a sdp file to descirbe the rtp session and use vlc to open this file.
you can refer to https://stackoverflow.com/questions/34983409/play-a-sdp-file-with-vlc
Hello @chlee.tw
Thank you for your reply. My computers os is Windows. And i think your solution is for linux. Do you know a solution for Windows?
Hello @arruda596
So, how can I stream a video and watch it on VLC? Do you know that?
Hello @chlee.tw
I create a sdp file;
But still, I cant watch the stream on VLC.
What am I doing wrong? Can you please help me?
Observer chlee.tw
Hi @yildiz.bilgin :
Hello @chlee.tw
It works!!! Thank you so much
Best regards
