Suggestion for Full HD video streaming using FPGA board?
I am trying to process 1080p video from an HD camera at 30fps on LVDS. Data rate per second would be around 1.8Gbps and I would like to split the data into 5 channels which would be sent to a DAC(Digital to analog converter). Please suggest me the desired clock required and an appropriate FPGA board which supports this.
Appreciate your time and concern.
Best,
Shashi
Scholar austin
Re: Suggestion for Full HD video streaming using FPGA board?
Look at:
reVision and the xcu102
https://www.xilinx.com/products/design-tools/embedded-vision-zone.html
https://www.xilinx.com/products/boards-and-kits/ek-u1-zcu102-g.html
It supports HDMI in & out, MIPI in, USB in.  Non-standard video is up to you to interface, but with the board's capabilities, it should be no issue to develop.
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank you for your valuable suggestion Austin.
I have a Zynq 7000 handy. would it be possible to do such operation using it instead of a Zynq Ultrascale.
I assume Ultrascale means a much lower nm technology or is there any significant difference between Zynq 7000 and Zynq Ultrascale?
Looking forward for your valuable inputs.
Thank you.
Scholar austin
Look at the supported boards for reVision,
Austin Lesea
Principal Engineer
Xilinx San Jose
Hi shashisvarna@gmail.com,
I don't think you need to use revision for this if you know a bit of RTL.
Zynq should be fine for the application if you want to do 1.8Gbps/5. The selectIO should support it.
You could even consider a spartan-7 for this type of application.
For the correct board, you might want to talk with an authorized distributor. They will point you
If everything is clear for you on this subject, please kindly mark a reply as solution to close the topic.
Thanks and Regards,
