Swap polarity MIPI D-Phy HS LVDS input
Setup:
  Vivado 2018.3
  Kintex-7
  MIPI CSI-2 Rx Subsystem 4.0
  Is there a way to swap P and N HS LVDS inputs in the IP configuration so that externally sensor datalane_p can be connected to FPGA LVDS_N as such.
  Is there a similar option for HS MIPI CLK input too?
Neo
Tags (2)
Re: Swap polarity MIPI D-Phy HS LVDS input
Hello Neo wtneo@leica
1. Unfortunately, XILINX MIPI D-PHY IP does not support P/N swap. ( at least for current release 2019.1, 2019.2)
    -- C_DL**_IO_SWAP is a hidden parameter for internal debug. Please ignore.
2. Sorry I cannot help on this and I do not suggest this, but manual netlist modification could be possible.
    ( For example swapping O/OB port connectivity of IBUFDS_DIFF_OUT )
Thanks & regards
Leo
I found a few properties for MIPI D-Phy in block diagram that seem to support inverting LVDS P and N input.  They are:
  1. C_DL0_IO_SWAP
  2. C_DL1_IO_SWAP
  3. C_DL2_IO_SWAP
  4. C_DL3_IO_SWAP
  5. C_CLK_IO_SWAP
Setting these properties to true, I am able to assign IP core's data input N port to P pin of FPGA's LVDS pairs.
I studied post bitgen schematics and found that Vivado physically swapped the N and P  signals before input to IBUFS.  See attached screen capture.  For example in attached schematic I set C_DL1_IO_SWAP = true.  The rest of the lanes are not swapped.
However, does MIPI D-Phy IP internally logically "NOT" the data from this lane such that it is the same polarity as other lanes?  Or MIPI D-Phy automatically detects the lane inversion during link training and handles that, much like AUTO-MDIX in Ethernet.
Neo
Thanks & regards
Leo
Adding to this knowledge, the way I work around the problem is applying the following constraints to the OSERDES in DPhy.
# flip PN for lane 2
set_property IS_D1_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D2_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D3_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D4_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D5_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D6_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D7_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master] set_property IS_D8_INVERTED 1'b1 [get_cells -hierarchical dl2_obufds_inst.dl2_oserdese2_master]
# flip PN for lane 3 set_property IS_D1_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D2_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D3_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D4_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D5_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D6_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D7_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master] set_property IS_D8_INVERTED 1'b1 [get_cells -hierarchical dl3_obufds_inst.dl3_oserdese2_master]
I have verified on hardware with Zynq 7 C1 device overclocked beyond 1.4Gbps. Receiver end is RK3399.
