Observer mflmfl
Sysgen Resource Estimator Croaks
I've got an ISE 13.3 Planahead project so those are the Xilinx blockset libs that I'm using.
Matlab version is R2011a.
When I run the Resource Estimator (RE) if I design a filter that exceeds the available DSP48 count available in the chip the RE correctly reports that as an error. So far so good.
When I back off the filter parameters to fit nicely into the target FPGA, I get an dialog box to perform mapping (there are blocks in the system with no estimation function).  When I click OK on this I get a java error:
Error using ==> xlCallMapper at 196
Java exception occurred:
com.xilinx.sysgen.netlist.NetlistInternal: there is no synopsis at
C:/Xilinx/13.3/ISE_DS/ISE/sysgen/scripts/SgMap.pm line 24
at
com.xilinx.sysgen.guitools.xlWaitBoxObjectInterface.quickCall(xlWaitBoxObjectInterface.java:482)
Observer mflmfl
Re: Sysgen Resource Estimator Croaks
Xilinx has indeed confirmed that this is a bug.
The workaround is to set the Project type (System Generator Token) to Project Navigator not PlanAhead. In that case the resource estimator will work just fine.
This looks like a bug.
I recommend opening a case with the Xilinx Technical Support.
http://www.xilinx.com/support/services/contact_info.htm
Chris
Video Design Hub | Embedded SW Support
Observer mflmfl
Would you know how to run the resource estimator from the command line?
Observer mflmfl
Ok, opened a webcase, thanks.
Observer mflmfl
