Visitor plant1976
TPG YUV 4:2:2 to Video Frame Buffer
I'm trying to design a simple FPGA with a TPG Video IP and a Video Frame Buffer.
The TPG is connected directly to Video Frame Buffer without Video Timing Controller.
When I try to configure the TPG and Video Frame Buffer to RGB888 anything works perfectly and I am to acquire images using the following command:
media-ctl -d /dev/media0 -V '"b0070000.v_tpg":0 [fmt:RGB888_1X24/1920x1080]'
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='RGB3'yavta -n 3 -c10 -f RGB24 -s 1920x1080 --skip 7 -F /dev/video0
When I try to set TPG and Video Frame Buffer to YUV 4:2:2 and acquire the images with following command, I am not able to acquire any images:
media-ctl -d /dev/media0 -V '"b0070000.v_tpg":0 [fmt:UYVY/1920x1080]'
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='YUYV'
yavta -n 3 -c10 -f YUYV -s 1920x1080 --skip 7 -F /dev/video0
The console output is:
Device /dev/video0 opened.
Device `video_cap output 0' on `platform:video_cap:0' is a video output (without mplanes) device.
Video format set: YUYV (56595559) 1920x1080 field none, 1 planes:
* Stride 3840, buffer size 4147200
Video format: YUYV (56595559) 1920x1080 field none, 1 planes:
3 buffers requested.
length: 1 offset: 3901633920 timestamp type/source: mono/EoF
Buffer 0/0 mapped at address 0x7fb3f3b000.
Buffer 1/0 mapped at address 0x7fb3b46000.
Buffer 2/0 mapped at address 0x7fb3751000.
Do you have any idea? do I have to put any video IP (like AXI4-Stream Subset Converter) between TPG to Video Frame Buffer when I use YUV422 configuration?
Thank you for your help.
Re: TPG YUV 4:2:2 to Video Frame Buffer
HI @plant1976 ,
This is a basic question but did you enable 422 in the frame buffer IP?
Florent
Hi @plant1976 ,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
