Test Pattern Generator - strange code problem /video timing ctrl not mapped.
Hello all,
Unfortunately I have a problem with the test pattern generator. I instantiated it in our project, together with the video timing controller,
but this last one is not mapped: as can be seen from the memory map in the attached image.
I find that strange code repeated on all registers (X "1CDEC0DE") including for example the version register of the macro, clear sign of a problem.
Unfortunately we can not understand what we could have done wrong.
Any suggestions?
Thanks in advance.
Best regards,
Andrea
Re: Test Pattern Generator - strange code problem /video timing ctrl not mapped.
Hi @andreac_avnet,
Can you also try updating the address in IPI?
This will validate 2 things. The first is that this is or is not address specific and the second is that we can be sure that the correct bitstream is being used.
If there is no change here, are you using an AXI interconnect or smart connect in your design? Can you post an image of your design or the BD?
Thank you,
Sam
Xilinx Video Design Hub
Hi @andreac_avnet,
To double check:
Have you verified that the parameter is correct?
#define XPAR_VTC_0_BASEADDR 0x44A30000
To get another data point does the vtc_selftest_example run correctly/return the same value (X "1CDEC0DE")?
The self test example is found in the system.mss by clicking import example
If you update the bitstream to re-arrange the addresses, do you still see the same result?
Sam
Hello @samk,
Thank you for the answer.
As evident from the screenshot attached above, the problem is precisely that there is nothing mapped to the address of the baseaddress:
Any code fails to do anything if nothing is mapped.
In addition, the XVtc_SelfTest function simply verifies that the version register is not equal to 0 and then passes successfully.
Best regards,
Andrea
Hi @andreac_avnet,
Thank you,
Sam
HI @andreac_avnet ,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Dear @florentw  and @samk,
Thanks for the help, I marked the solution.
Best regards,
Andrea
