Two 1080p 30fps video streams
I would like to know if it is possible to run two video streams 1080p 30 fps simultaneously trough the H.264 / H.265 encoder/decoder of the Zynq MPSoC?
Kees
Kees van Egmond
FAE 4 Xilinx @ Avnet Silica Netherlands
Tags (2)
Re: Two 1080p 30fps video streams
Hi Kees @kvanegmond,
Refer to the pg252:
You can encode/decode up to 8 simultaneous streams as long as the total bandwidth is below 4k@60.
Thus 2x1080p30 is perfectly fine. You could even have 8 x 1080p30 stream simultaneously.
Florent
Refer to the pg252:
Florent
