Type mismatch between connected pins in HDMI RX and TX IPs
In my design I am using the HDMI 1.4/2.0 Transmitter and Receiver IPs from Xilinx.
When I open the block design I get these 2 messages:
WARNING: [BD 41-1731] Type mismatch between connected pins: /v_hdmi_rx/m_axis_video_aresetn_out(undef) and /v_vid_in_axi4s/aresetn(rst)
WARNING: [BD 41-1731] Type mismatch between connected pins: /v_hdmi_tx/s_axis_video_aresetn_out(undef) and /v_axi4s_vid_out/aresetn(rst)
I get the same messages when I open the 2 example projects: v_hdmi_rx_ss_0_ex and v_hdmi_tx_ss_0_ex.
Is this OK?
jmcm
Tags (2)
Re: Type mismatch between connected pins in HDMI RX and TX IPs
HI @jmcm,
Is everything clear for you on this? As per @bpatil's reply, this warning can be ignored. We will try to have it fixed for a future version.
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Florent
Hi @jmcm
I have checked v_hdmi_tx_ss_0_ex example design for ZCU102 board with Vivado 2018.2. I do not see any error/warning as you mentioned below:
Provide details of Vivado version and Board details (which you are targeting for running example design).
Bhushan
Bhushan
Hi Bhushan,
Board: ZCU104
Vivado: v2018.2.1 (64-bit)
Jmcm
Hi @jmcm
I tried to reproduce this issue at my end for running v_hdmi_tx_ss_0_ex on Vivado 2018.2.1 with ZCU104 board.
But I do not see any warning related to type mismatch as you mentioned.
My implemented design schematic design as follows:
Are you trying make any changes in default example design? If not, then it should get implemented without any problems.
Try to rerun HDMI example design in directory having no space in directory path.
For example: C:\XilinxProjects\HDMI_EX\
Bhushan
Bhushan
Hi @jmcm
Share XCI file of your application for further debugging.
Bhushan
Bhushan
Hi @jmcm
I checked xci provided by you. But I do not see any error at my end.
HDMI RX Results as follows:
HDMI TX Results as follows:
Please try to reduce project path length; as at starting I too got got few errors related to synthesis (some module were not able to synthesis) reduction in project path length of project caused successful implementation of both modules.
EDIT1: I have reproduced error by closing and reopening block diagram in example design. But it went away after I right clicked on block diagram and clicked validate design.
Bhushan
Bhushan
HI @jmcm,
Best Regards,
Florent
