UDA1334BTS
I am using DAC UDA1334BTS with XIlinx I2S IP. The serial data is coming out of IP. But the DAC is not producing an output.
Re: UDA1334BTS
Hi @raghusrinivas451993,
You might want to ask help from NXP. If there are serial data out from the FPGA, this is coming from the DAC UDA1334BTS
Florent
Re: UDA1334BTS
HI @raghusrinivas451993,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
