UHD SDI Example Design - Vivado Version
Which version of Vivado supports ZCU106?
I am trying to set up a UHD-SDI example design for one of my projects. The example design is available only for ZCU106. I tried with 2017.2, 2017.3 and 2017.4. None of them seems to support ZCU106.
Or, is there a special installation to add this board to Vivado?
Ajay.
Re: UHD SDI Example Design - Vivado Version
Hello @ajaykumargurrala,
Do you have access for the EA lounge of this board ?
It will have steps to add the feature of this board into the tool.
Also refer the below link:
https://www.xilinx.com/products/intellectual-property/uhd-serial-digital-interface/uhd-serial-digital-interface-software-requirements.html
UHD-SDI is supported from 2017.3 version of vivado.
Please reach to licensing center for more help.
https://www.xilinx.com/support/licensing_solution_center.html
Hope this helps.
Thank you.
Hope this helps.
Thank you.
Hi @ajaykumargurrala,
Generating the UHD-SDI example design in 2017.3 and 2017.4 is documented in AR#70063.
Users shouldn't need to have the EA license for the ZCU106. Just select the production part xczu7ev-ffvc1156-2-i and you can generate the UHD-SDI exdes.
Hi Florent,
I have tried this out! I get the same error message which reports xczu7ev-ffvc1156-2-i_es2 part is missing and the example design is not generated completely.
I am using Vivado 2017.4.1
I have attached the snapshots of the error message and the project window of the generated design. the error message screen shot was older but i get the same message but with part number updated.
I have followed the following steps.
-I have opened the common vivado 2017.4.1 project which i have created to use in generating example designs
-I have changed the part number to the part number suggested by you
-I have added the UHD-SDI RX subsystem to block design, configured it as 3G SDI , right click and generate IP example design.
A new project was opened with the example design, which has thrown an error message as shown in attachment1(capture.png) and ended up as shown in attachment2(capture2.png).
Did i miss anything in the flow?
Thanks and Regards,
Ajay.
You are right sorry. I thought the goal of the patch (from the AR) was to enable any customer to generate the UHD-SDI exdes...
Let me clarify that.
We have updated the patch from AR#70593. This allows user to generate the UHD-SDI on production silicon (i.e. no need for ES2 license).
Best Regards,
Hi @florentw
Thanks a lot! I could now successfully generate the example design for UHD SDI subsystem. I am actually working to build an optical SDI link using SFPs. I want to take up the base SDI example, port it for ZCU102 and modify it accordingly to achieve the intended functionality.
I will post the results once i progress.
Any suggestions would be of great help.
Thanks and Regards.
Ajay Kumar G
