UHD-SDI Example design - ZCU102 Version
I had to create a ZCU102 version of UHDSDI example design for one of my projects. I could create the copy of ZCU106 UHDSDI example design retargeted to ZCU102 by tweaking the example design generation script files of UHDSDI_RX_SS IP.
Adding the source and generation script files here so that anyone in need of such a design can make use of this. A read me file is added to the archive with necessary details on using the script to regenerate the design.
Please note, that the XDC is still of ZCU106. It can be modified accordingly after generating the design.
Ajay
Re: UHD-SDI Example design - ZCU102 Version
Hi @ajaykumargurrala,
Thank you for sharing.
Florent
Newbie cfritz68
Thanks for sharing this.  One question about this IP, I have a design where I need to use 6G-SDI data rate to transmit a non standard 2560x1440 at 60p. Will this IP accept non-standard video formats?
CF
AR62645 should also apply to the UHD-SDI IP as well.
The UHD-SDI Subsystems should be capable of supporting non-standard resolutions, but only the standard SDI resolutions are tested and the user would need to do their own testing for non-standard resolutions.
Chris
Video Design Hub | Embedded SW Support
If you have question about the UHD-SDI IP, please create a new topic.
I am closing this topic for new replies.
Florent
