Observer rathna
Unable to set the synchronization ZCU102 - HDMI output
I'm trying to display an image loaded onto the BRAM on an HDMI monitor. I'm using the same flow from the HDMI tx ss example project. However, I'm unable to get the synchronization correct on the screen. To illustrate this, I have attached the following images. Kindly, help me resolve this.
The checkered box is my input image, and my output is a shifted black and white diagonal lines.
Observer rathna
Re: Unable to set the synchronization ZCU102 - HDMI output
I changed and recreated my project and there were some changes that needed to be made with the SDK. I discontinued the use of the example design.
And now, it works fine.
So, that solved my problem.
Scholar watari
Hi @rathna
Would you share the followings ?
- LCD display name and part number
- Output video resolution and pixel clock frequency on FPGA
- Resolution and clock frequency information on OSD of your display, when it occurs
Observer rathna
1. I am using the Samsung SyncMaster 943 monitor.
2. Resolution: 1280x720@50Hz Pixel clock freq: 74.25MHz. It is the same for the OSD too.
However, I'm tweaking the data and giving data from an image store in Bram. So, I don't know how to fix it.
Scholar watari
Hi @rathna
Can you share this way ?
Observer rathna
So this is the HDMI passthrough example design from the HDMI tx ss. Here, the TPG takes in the video input from an HDMI source. While the control signals are the same. But, I am sending the data from the BRAM. I've also attached the image below.
Thanks and Regards.
Scholar watari
Hi @rathna
# About wrong picture
In this case, I guess the address and data signals on BRAM and the control signals on AXI4Stream are a-synchronized.
Also, it ignores sol, eol, sof and eof.
So the picture is broken.
# About tweaking the data
In this case, I guess it seems to be synchronized between the control signals on AXI4Stream and address and data signals.
So it seems to work fine.
# My suggestion
You prepare a timing controller by AXI4Stream clock to read video data on BRAM.
Would you try it, if necessary ?
Observer rathna
I just want to display stored image in BRAM through HDMI or any other possible ports using ZCU102.
Any inputs on this?
Scholar watari
Hi @rathna
As I already mentioned before, you need to implement timing controller to read video data from BRAM via AXI4Stream.
Would you try it ?
I'm probably sure that  this way is better solution for you.
Observer rathna
I've tried to use the Video Timing Controller along with BRAM for AXI-stream. But, when I do this, I get absolutely no output on the screen.
In fact, I wrote an HLS code in order to display a red box. When I only connect the data port, I get the unsynchronized output. When I connect all the control signals, I get no output on the screen. That is why I asked you if there was a simpler way to display an image on the screen.
Scholar watari
Hi @rathna
I'm not familiar with Video pattern generator. However, at least you need to set some parameters via AXI4Lite from microblaze and so on.
In this case, you need to synchronize among AXI4Stream control signals and Video data and timing generator.
Would you try it ?
# Hint
- AXI4Stream signal control logic
- Timing generator for BRAM (Read video data by synchronized video timing from BRAM)
- CDC logic or FIFO
Hi @rathna,
If your question is answered or your issue is solved, please mark the response which helped as solution (click on the button "Accept as solution" below the reply)
Best Regards,
Observer rathna
