Visitor bmassil
Using 2 NGC from SysGenerator in ISE project gives error?
I generated 2 models in system generator and wish to connect them together in a ISE project. If I add only one NGC to my project, it works fine. But when I add the second one, I have 96 errors that say:
XdmHelpers:678 Processing property "OFFSET=OUT 20000 pS AFTER clk ... Net "clk" not found.
Can anyone provide insight?
Many thanks,
Re: Using 2 NGC from SysGenerator in ISE project gives error?
This is most likely an issue with the constraints.  You may want to double check the hierarchy in the XCF and/or UCF being used.
Something to consider; ISE and System Generator 10.1 have several new features that make importing multiple SysGen designs into one ISE project better.
