Using MIPI CSI-2 and LI-IMX274MIPI-FMC in my own design
Hi~
Recently, our design need a digital camera,  so I'm thinking is there any tutorial that can help me integrate an LI-IMX274MIPI-FMC in our system
Thanks~
Tags (2)
Re: Using MIPI CSI-2 and LI-IMX274MIPI-FMC in my own design
HI eleicoto@outlook.com
No there is not specific tutorail but you can generate the MIPI CSI-2 example on ZCU102 this would give you a good reference to start with. Refer to PG232 Chapter 5.
The you just have to port this design to your board.
Florent
Florent
Thanks for your reply, I have been following this guide to design my system, but there is a problem, it seems like the license I used is not allowed to access MIPI or HDMI IP, so how can I get these license?
Go to your licensing account and find the cores in the "evaluation and no charges cores". Then you will be able to generate the evaluation license for the cores.
Florent
Thanks for your help, I guess I will use evaluation license first.
