Observer bhig
VCU 2018.3 TRD 8 display stream example fails
I am trying to run the "8_1080p30_HEVC_7_5Mbps.cfg" example from the VCU TRD v2018.3.  I am just using the prebuilt images from .\images\vcu_trd\ with a ZCU106 rev 1.0 board and a 1080p monitor. I am driving the HDMI Input from a computer and also am using a MIPI camera, the suggested LI-IMX274MIPI-FMC.
My issue is when running the 8 video streams example, after anyway from 30 seconds to a few minutes the output will stop, the monitor reverts back to the blue modetest screen and the below error is output. Also, the performance is pretty laggy on both the outputted MIPI video and the computer video output.
When running the AVC example, it does not seem to crash but instead the video is very choppy and I a lot of mipi_rx_subsystem buffer full errors as shown in the 2nd output.
Has anyone else seen these issues?
root@zcu106_vcu_trd:~# vcu_gst_app 8_1080p30_HEVC_7_5Mbps.cfg
/*************************Pipeline Information Start*************************/
Pipeline Info : On
Fps Info : On
APM Info : On
Output goes on : HDMI
/*************************Pipeline Information End*************************/
[ 2172.459353] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
Encoder Memory Bandwidth (5.32 Gbps)
Decoder Memory Bandwidth (2.53 Gbps)
Pipeline [1] Fps[7]
Pipeline [2] Fps[6]
Pipeline [4] Fps[1]
Encoder Memory Bandwidth (23.82 Gbps)
Decoder Memory Bandwidth (14.00 Gbps)
Pipeline [5] Fps[13]
Pipeline [6] Fps[17]
Pipeline [7] Fps[0]
Pipeline [8] Fps[0]
Cannot open device file /dev/allegroDecodeIP: Too many open files
vcu_gst_app: ../src/uio_perfmon.c:178: u32 uPerfMon_Check_SIC_Overflow_Mask(): Assertion `pmon_handle.IsReady ==     XIL_COMPONENT_IS_READY' failed.
Aborted
root@zcu106_vcu_trd:~# vcu_gst_app 8_1080p30_AVC_7_5Mbps.cfg
Pipeline Info : On
Fps Info : On
APM Info : On
Frame rate : 30
Number of Source is : 8
Use case is to : Display
B Frames : 0
Bitrate : 7500
Enable L2Cache : True
Enc Name : AVC
Gop Len : 60
Profile : High
Qp Mode : Auto
Rc Mode : CBR
Num Slice : 8
GoP Mode : Basic
Filler Data : True
Low Bandwidth : False
Latency Mode : Normal
Device Type : HDMI
For[ 4267.131851] xilinx-vpss-csc a0240000.v_proc_ss: VPSS CSC color controls reset to defaults
mat : NV12
Width : 1920
Height : 1080
!! The specified Level is too low and will be adjusted !!
[ 4268.040386] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
Encoder Memory Bandwidth (6.71 Gbps)
Decoder Memory Bandwidth (3.52 Gbps)
Pipeline [1] Fps[6]
Pipeline [2] Fps[0]
Pipeline [3] Fps[0]
Pipeline [4] Fps[0]
Pipeline [5] Fps[0]
Pipeline [6] Fps[0]
Pipeline [7] Fps[0]
Pipeline [8] Fps[0]
[ 4269.410922] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4269.508044] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4269.605938] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4269.677817] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4269.806277] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4269.974589] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
Encoder Memory Bandwidth (20.72 Gbps)
Decoder Memory Bandwidth (16.57 Gbps)
Pipeline [1] Fps[6]
Pipeline [2] Fps[11]
Pipeline [3] Fps[46]
Pipeline [4] Fps[41]
Pipeline [5] Fps[27]
Pipeline [6] Fps[40]
Pipeline [7] Fps[0]
Pipeline [8] Fps[0]
[ 4270.206751] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
[ 4270.378445] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
... and so it continues until stopping
Encoder Memory Bandwidth (25.51 Gbps)
Decoder Memory Bandwidth (21.25 Gbps)
Pipeline [7] Fps[0]
Pi[ 4557.079184] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
peline [8] Fps[0]
[ 4557.111402] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
Decoder Memory Bandwidth (21.25[ 4558.017773] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Ful l!
 Gbps)
Pipeline [1] Fps[0]
Encoder Memory Bandwidth (24.41 Gbps)
Decoder Memory Bandwidth (20.85 Gbps)
Pipeline [2] Fps[24]
Decoder Memory Bandwidth (20.54 Gbps)
Pipeline [3] Fps[0]
Pipeline [4] Fps[0]
Pipeline [5] Fps[0]
Pipeline [6] Fps[0]
Pipeline [7] Fps[0]
Pipeline [8] Fps[0]
[ 4558.214768] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Stream Line Buffer Full!
^CHit Ctrl-C
Quitting the app now
Quitting the loop
playback count 1
pipeline stopped successfully
Bryan
Re: VCU 2018.3 TRD 8 display stream example fails
Hello @bhig
Yes, this is known and I have personally reproduced this issue.
In few of the planes you see flicker or hang. But in our case it was not going back to blue screen.
can you share your config file you tested ? I will take a quick look into that.
This is expected to get fixed in 2019.1 version.
Thank you
Hello @bhig
Thank you
Observer bhig
Hi @kvasantr  thanks for the response!  Good to know it will be fixed soon.
I attached both the AVC and HEVC 8 stream config files, however just the HEVC one exhibits the "Cannot open device file /dev/allegroDecodeIP: Too many open files" followed by the "vcu_gst_app: ../src/uio_perfmon.c:178: u32 uPerfMon_Check_SIC_Overflow_Mask(): Assertion `pmon_handle.IsReady == XIL_COMPONENT_IS_READY' failed." error that aborts the program and returns to the blue screen.
Bryan
Hello @bhig
Thank you for sharing config files. They are as expected and as same as the one with which i had tested.
Thank you once again for reporting. Please close this thread by marking accepted solution.
