Observer ericzerbib
VCU Framework - resolution change event
Hello all
Is it possible to an application running the VCU TRD 2018.3 framework to get event/interrupt when the HDMI In is disconnected or when the resolution is changed ( 1080p to 4k60) or p30 to 60 etc.
Re: VCU Framework - resolution change event
This is not really a VCU question, but more of an HDMI question.
HDMI Rx uses the V4L2 framework as documented on the HDMI RX Wiki Page.
HDMI Rx will issue an interrupt when the resolution changes or the HDMI input unplugged.
Chris
Video Design Hub | Embedded SW Support
Chris
Observer ericzerbib
Thanks for your input
