Visitor bilal5330
VCU TRD 2019.1 Streaming RTP video to Board using VLC Player
I am using HDMI Tx example design in VCU TRD 2019.1 on ZCU106 board to display VCU decompressed video on HDMI.
The example works fine if I read video file from SD Card or USB.
However I want to stream the same video now from VLC player on Desktop PC to the ZCU106 board, connected through a nework.
I have disabled the firewall and both Desktop PC and ZCU106 can ping each other.
However when I run the application 'vcu_gst_app' with cfg file containing the information to get input from network stream, I get the following error immediately and application returns.
/*************************Pipeline Information End*************************/
ERROR: vgst_start_pipeline() failed error code "state change failed"
pipeline stopped successfully
When I run the following command (APPENDIX-B, VCU HDMI Tx) https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/116031534/Zynq+UltraScale+MPSoC+VCU+TRD+2019.1+-+HDMI+Video+Display
$ gst-launch-1.0 udpsrc port=5004 buffer-size=60000000 caps="application/x-rtp, clock-rate=90000" ! rtpjitterbuffer latency=1000 ! rtpmp2tdepay ! tsparse ! video/mpegts ! tsdemux name=demux ! queue ! h265parse ! video/x-h265, profile=main, alignment=au ! omxh265dec internal-entropy-buffers=5 low-latency=0 ! queue max-size-bytes=0 ! kmssink bus-id="a0070000.v_mix"
I get the following error.
../../../git/gst/rtpmanager/gstrtpjitterbuffer.c(3247): gst_rtp_jitter_buffer_chain (): /GstPipeline:pipeline0/GstRtpJitterBuff er:rtpjitterbuffer0:
Received invalid RTP payload, dropping
Can anyone guide me what settings I should do at VLC end to successully stream the video from VLC to the ZCU106 board.
Or is there any guide/discussion link for this. I searched whole forums but couldn't get related information.
PS: I can stream the video between two PCs on the network using VLC using RTP, and it works fine.
Thank you in advance,
Bilal
Visitor bilal5330
Re: VCU TRD 2019.1 Streaming RTP video to Board using VLC Player
I solved the issue by using GStreamer to stream out video pattern from PC, instead of VLC.
I used the following settings on PC end.
PC IP: 192.168.0.9
ZCU106 IP: 192.168.0.10
On PC End:
gst-launch-1.0 videotestsrc ! video/x-raw, format=NV12, width=1920, height=1080, framerate=50/1 ! omxh265enc qp-mode=auto gop-mode=basic gop-length=60 b-frames=0 target-bitrate=60000 num-slices=8 control-rate=constant prefetch-buffer=true low-bandwidth=false filler-data=true cpb-size=1000 initial-delay=500 periodicity-idr=60 ! video/x-h265, profile=main, alignment=au ! queue ! mpegtsmux alignment=7 name=mux ! rtpmp2tpay ! udpsink host=192.168.0.10 port=5004
On ZCU106 End:
It worked fine.
Scholar watari
Hi @bilal5330
Would you run gst-launch-1.0 with an option as "gst-debug-level=5" ?
Visitor bilal5330
PC IP: 192.168.0.9
On PC End:
On ZCU106 End:
It worked fine.
