Visitor ahmed_barco
VCU TRD (vcu_10G)
We are trying to make the Zynq UltraScale+ MPSoC VCU TRD 2019.1 - 10G HDMI Video Capture and HDMI Display work on a ZCU106.
After booting up I did the following :
1- modetest -M xlnx : to check the monitor resolutions
2- modetest -M xlnx -D a0070000.v_mix -s 40:1024x768-60@BG24 : Set one of the resolutions (color bars on the screen then blue after hitting enter)
3- vcu_gst_app /media/card/config/1080p60/Stream-out/Single_1080p60_HEVC_HIGH.cfg : start the streaming
But I get the follwing error :
Couldnt allocate dma allocator (tried using /dev/allegroIP)
ERROR: vgst_start_pipeline() failed error code "state change failed"
pipeline stopped successfully.
The terminal :
root@zcu106_vcu_trd:~# modetest -M xlnx
Encoders:
id      crtc    type    possible crtcs  possible clones
39      38      TMDS    0x00000001      0x00000000
Connectors:
id      encoder status          name            size (mm)       modes   encoders
40      39      connected       HDMI-A-1        500x310         8       39
  modes:
        name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
  1920x1200 60 1920 1968 2000 2080 1200 1203 1209 1235 154000 flags: phsync, nvsync; type: preferred, driver
  1600x1200 60 1600 1664 1856 2160 1200 1201 1204 1250 162000 flags: phsync, pvsync; type: driver
  1280x1024 60 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver
  1280x960 60 1280 1376 1488 1800 960 961 964 1000 108000 flags: phsync, pvsync; type: driver
  1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
  800x600 60 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
  640x480 60 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
  720x400 70 720 738 846 900 400 412 414 449 28320 flags: nhsync, pvsync; type: driver
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
                        00ffffffffffff004dd9d002a12d9100
                        1510010380321f78eafd85a3574a9e25
                        135054a10800a9408180814001010101
                        010101010101283c80a070b023403020
                        3600ef351100001a483f403062b03240
                        40c01300ef351100001e000000fd0039
                        3f1c4b10000a202020202020000000fc
                        0053444d2d503233340a2020202000c2
        2 DPMS:
                flags: enum
                enums: On=0 Standby=1 Suspend=2 Off=3
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        19 CRTC_ID:
                flags: object
                value: 38
CRTCs:
id      fb      pos     size
38      0       (0,0)   (1024x768)
  props:
        20 ACTIVE:
                flags: range
                values: 0 1
                value: 1
        21 MODE_ID:
                flags: blob
                blobs:
                value:
                        e8fd000000041804a004400500000003
                        03030903260300003c0000000a000000
                        40000000313032347837363800000000
                        00000000000000000000000000000000
                        00000000
        18 OUT_FENCE_PTR:
                flags: range
                values: 0 18446744073709551615
                value: 0
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
30      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                flags: immutable enum
                enums: Overlay=0 Primary=1 Cursor=2
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                values: -1 2147483647
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                values: -2147483648 2147483647
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                values: 0 2147483647
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                values: 0 4294967295
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
31      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
32      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
33      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
34      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
35      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
36      0       0       0,0             0,0     0               0x00000001
  formats: AR24
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
        29 alpha:
                flags: range
                values: 0 256
                value: 0
37      0       0       0,0             0,0     0               0x00000001
  formats: BG24
  props:
        7 type:
                value: 1
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 1024
        15 CRTC_H:
                flags: range
                value: 768
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 67108864
        11 SRC_H:
                flags: range
                value: 50331648
Frame buffers:
id      size    pitch
root@zcu106_vcu_trd:~# modetest -M xlnx -D a0070000.v_mix -s 40:1024x768-60@BG24
setting mode 1024x768-60Hz@BG24 on connectors 40, crtc 38
root@zcu106_vcu_trd:~# vcu_gst_app /media/card/config/1080p60/Stream-out/Single_1080p60_HEVC_HIGH.cfg
Warning!! fps info should be disabled for Record/streaming option
/*************************Pipeline Information Start*************************/
Pipeline Info : On
Fps Info : Off
APM Info : On
Output goes on : HDMI
Frame rate : 60
Number of Source is : 1
Use case is to : Stream
B Frames : 0
Bitrate : 60000
Enable L2Cache : True
Enc Name : HEVC
Gop Len : 60
Profile : Main
Qp Mode : Auto
Rc Mode : CBR
Num Slice : 8
GoP Mode : Basic
Filler Data : True
Low Bandwidth : False
Latency Mode : Normal
Device Type : HDMI
Format : NV12
Width : 1920
Height : 1080
Raw : False
Accelerator flag : False
Enable_scd flag : False
Src Type : Live Src
Streaming at IP : 192.168.26.89
Streaming at Port : 5004
/*************************Pipeline Information End*************************/
Tags (3)
Scholar watari
Re: VCU TRD (vcu_10G)
Hi @ahmed_barco
What source device do you use ? Desktop PC ?
If yes, it's EDID issue.
You need to change suitable EDID. It's an easy way to resolve this issue.
BTW, perhapse, it might be unstable setting on V4L2 bus.
So, would you share the result of following commands ?
I guess /dev/media8 is correct. If the result is not suitable, would you change number of media device ?
$ xmedia-ctl -p -d /dev/media8
$ v4l2-ctl --all
Best regards,
Visitor ahmed_barco
Hello @watari ,
First thanks for your reply.
To answer your questions:
1- I am using a laptop as an HDMI source and as far as I can see the input is good (can set to max 4k30p). The output part is what is not working properly.
2- here is the output of the commands (I sent them directly after the autoboot completed)
NOTE : in autostart.sh I changed the resolution to "modetest -D a0070000.v_mix -s 40:1024x768-60@BG24 -w 36:"alpha":0 &" to make the output work.
root@zcu106_vcu_trd:~# xmedia-ctl -p -d /dev/media0
Media controller API version 4.19.0
Media device information
driver          xilinx-video
model           Xilinx Video Composite Device
serial
bus info
hw revision     0x0
driver version  4.19.0
Device topology
- entity 1: vcap_hdmi output 0 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "a0080000.v_proc_ss":1 [ENABLED]
- entity 5: a0080000.v_proc_ss (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
        pad0: Sink
                [fmt:Y8_1X8/1280x720 field:none colorspace:srgb]
                <- "a0000000.v_hdmi_rx_ss":0 [ENABLED]
        pad1: Source
                [fmt:Y8_1X8/1920x1080 field:none colorspace:srgb]
                -> "vcap_hdmi output 0":0 [ENABLED]
- entity 8: a0000000.v_hdmi_rx_ss (1 pad, 1 link)
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:RBG888_1X24/1920x1080 field:none colorspace:srgb]
                [dv.caps:BT.656/1120 min:0x0@25000000 max:4096x2160@297000000 stds:CEA-861,DMT,CVT,GTF caps:progressive,reduced-blanking,custom]
                [dv.detect:BT.656/1120 1920x1080p60 (2200x1125) stds:CEA-861 flags:CE-video]
                -> "a0080000.v_proc_ss":0 [ENABLED]
root@zcu106_vcu_trd:~# v4l2-ctl --all
Driver Info:
        Driver name      : xilinx-vipp
        Card type        : vcap_hdmi output 0
        Bus info         : platform:vcap_hdmi:0
        Driver version   : 4.19.0
        Capabilities     : 0x84201000
                Video Capture Multiplanar
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04201000
                Streaming
                Extended Pix Format
Media Driver Info:
        Driver name      : xilinx-video
        Model            : Xilinx Video Composite Device
        Serial           :
        Bus info         :
        Media version    : 4.19.0
        Hardware revision: 0x00000000 (0)
Interface Info:
        Type             : V4L Video
Entity Info:
        Name             : vcap_hdmi output 0
        Function         : V4L2 I/O
        Pad 0x01000002   : 0: Sink
          Link 0x0200000c: from remote pad 0x1000007 of entity 'a0080000.v_proc_ss': Data, Enabled
Priority: 2
Format Video Capture Multiplanar:
        Width/Height      : 1920/0
        Pixel Format      : 'YUYV'
        Field             : None
        Number of planes  : 0
        Flags             :
        Colorspace        : sRGB
        Transfer Function : Default
        YCbCr/HSV Encoding: Default
        Quantization      : Default
Looking forward to hear from you
Scholar watari
Hi @ahmed_barco
Because of there is contradiction on following media bus setting and it is a route cause.
Device topology
pad0: Sink
pad0: Sink
pad1: Source
pad0: Source
So, would you change the followings ?
$ xmedia-ctl -d /dev/media8 "a0080000.v_proc_ss":1 [fmt:VYYUYY8_1X24/1920x1080 filed:none]
$ xmedia-ctl -d /dev/media8 "a0080000.v_proc_ss":0 [fmt:RBG888_1X24/1920x1080 filed:none]
Best regards,
Visitor ahmed_barco
Hello @watari
I followed your instructions but it didn't fix the issue.
I copied a new image (original image for vcu_10g) on the SD Card and start the whole process.
The terminal output :
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1   Jul 10 2019  -  14:03:51
NOTICE:  ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x10080000
NOTICE:  BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790
NOTICE:  BL31: Built : 14:00:54, Jul 10 2019
PMUFW:  v1.1
U-Boot 2019.01 (Jul 10 2019 - 14:01:44 +0000)
Model: ZynqMP ZCU106 RevA
Board: Xilinx ZynqMP
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu7ev
MMC:   mmc@ff170000: 0
Loading Environment from SPI Flash... SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Reset reason:   EXTERNAL
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 MAC addresses don't match:
Address in ROM is          00:0a:35:05:08:4a
Address in environment is  00:0a:35:00:22:01
eth0: ethernet@ff0e0000
Device: mmc@ff170000
Manufacturer ID: 74
OEM: 4a45
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
166829940 bytes read in 10734 ms (14.8 MiB/s)
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x10000104
     Data Size:    18217472 Bytes = 17.4 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   5230c6067e04375e9437a3e5dbb687b5cfb361cf
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Compression:  gzip compressed
     Data Start:   0x1116cc28
     Data Size:    148557244 Bytes = 141.7 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   ce0e7c26f1f7b3151ace5b15c92f1b7fedc62fa9
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x1115fc08
     Data Size:    53084 Bytes = 51.8 KiB
     Hash algo:    sha1
     Hash value:   6e1f848891ce270ab4624928198e1c73f520bece
   Booting using the fdt blob at 0x1115fc08
   Loading Kernel Image ... OK
   Loading Ramdisk to 74ff0000, end 7dd9cdbc ... OK
   Loading Device Tree to 0000000074fe0000, end 0000000074feff5b ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Wed Jul 10 14:01:49 UTC 2019
[    0.000000] Machine model: ZynqMP ZCU106 RevA
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 1700 MiB at 0x000000000a800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[    0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1033987
[    0.000000] Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB: mapped [mem 0x06800000-0x0a800000] (64MB)
[    0.000000] Memory: 2158592K/4193280K available (10812K kernel code, 638K rwdata, 5444K rodata, 832K init, 509K bss, 293888K reserved, 1740800K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[    0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[    0.008289] Console: colour dummy device 80x25
[    0.012377] console [tty0] enabled
[    0.015743] bootconsole [cdns0] disabled
[    0.019657] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[    0.019670] pid_max: default: 32768 minimum: 301
[    0.019784] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019802] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020527] ASID allocator initialised with 32768 entries
[    0.020579] rcu: Hierarchical SRCU implementation.
[    0.020938] EFI services will not be available.
[    0.021059] smp: Bringing up secondary CPUs ...
[    0.021337] Detected VIPT I-cache on CPU1
[    0.021366] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.021675] Detected VIPT I-cache on CPU2
[    0.021694] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.021981] Detected VIPT I-cache on CPU3
[    0.022000] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.022043] smp: Brought up 1 node, 4 CPUs
[    0.022077] SMP: Total of 4 processors activated.
[    0.022085] CPU features: detected: 32-bit EL0 Support
[    0.023628] CPU: All CPU(s) started at EL2
[    0.023660] alternatives: patching kernel code
[    0.024541] devtmpfs: initialized
[    0.030197] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030221] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.066162] xor: measuring software checksum speed
[    0.103840]    8regs     :  2375.000 MB/sec
[    0.143865]    8regs_prefetch:  2052.000 MB/sec
[    0.183896]    32regs    :  2724.000 MB/sec
[    0.223925]    32regs_prefetch:  2308.000 MB/sec
[    0.223933] xor: using function: 32regs (2724.000 MB/sec)
[    0.223948] pinctrl core: initialized pinctrl subsystem
[    0.224594] NET: Registered protocol family 16
[    0.224874] audit: initializing netlink subsys (disabled)
[    0.224943] audit: type=2000 audit(0.216:1): state=initialized audit_enabled=0 res=1
[    0.225362] cpuidle: using governor menu
[    0.225493] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.225506] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.226214] DMA: preallocated 256 KiB pool for atomic allocations
[    0.241195] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.308117] raid6: int64x1  gen()   446 MB/s
[    0.376145] raid6: int64x1  xor()   453 MB/s
[    0.444154] raid6: int64x2  gen()   680 MB/s
[    0.512248] raid6: int64x2  xor()   599 MB/s
[    0.580258] raid6: int64x4  gen()   981 MB/s
[    0.648319] raid6: int64x4  xor()   736 MB/s
[    0.716364] raid6: int64x8  gen()  1163 MB/s
[    0.784443] raid6: int64x8  xor()   759 MB/s
[    0.852477] raid6: neonx1   gen()   735 MB/s
[    0.920540] raid6: neonx1   xor()   879 MB/s
[    0.988601] raid6: neonx2   gen()  1128 MB/s
[    1.056633] raid6: neonx2   xor()  1172 MB/s
[    1.124702] raid6: neonx4   gen()  1477 MB/s
[    1.192743] raid6: neonx4   xor()  1417 MB/s
[    1.260794] raid6: neonx8   gen()  1529 MB/s
[    1.328833] raid6: neonx8   xor()  1459 MB/s
[    1.328841] raid6: using algorithm neonx8 gen() 1529 MB/s
[    1.328848] raid6: .... xor() 1459 MB/s, rmw enabled
[    1.328856] raid6: using neon recovery algorithm
[    1.329681] SCSI subsystem initialized
[    1.329877] usbcore: registered new interface driver usbfs
[    1.329917] usbcore: registered new interface driver hub
[    1.329958] usbcore: registered new device driver usb
[    1.330029] media: Linux media interface: v0.10
[    1.330057] videodev: Linux video capture interface: v2.00
[    1.330087] pps_core: LinuxPPS API ver. 1 registered
[    1.330096] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.330119] PTP clock support registered
[    1.330150] EDAC MC: Ver: 3.0.0
[    1.330561] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[    1.330783] FPGA manager framework
[    1.330964] Advanced Linux Sound Architecture Driver Initialized.
[    1.331242] Bluetooth: Core ver 2.22
[    1.331272] NET: Registered protocol family 31
[    1.331280] Bluetooth: HCI device and connection manager initialized
[    1.331292] Bluetooth: HCI socket layer initialized
[    1.331302] Bluetooth: L2CAP socket layer initialized
[    1.331326] Bluetooth: SCO socket layer initialized
[    1.331638] clocksource: Switched to clocksource arch_sys_counter
[    1.331714] VFS: Disk quotas dquot_6.6.0
[    1.331759] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.336223] NET: Registered protocol family 2
[    1.336589] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[    1.336640] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.336848] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.337250] TCP: Hash tables configured (established 32768 bind 32768)
[    1.337319] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337397] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337551] NET: Registered protocol family 1
[    1.337796] RPC: Registered named UNIX socket transport module.
[    1.337805] RPC: Registered udp transport module.
[    1.337813] RPC: Registered tcp transport module.
[    1.337820] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.338166] Trying to unpack rootfs image as initramfs...
[    7.643917] Freeing initrd memory: 145072K
[    7.644379] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    7.644548] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    7.645551] Initialise system trusted keyrings
[    7.645639] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    7.646331] NFS: Registering the id_resolver key type
[    7.646350] Key type id_resolver registered
[    7.646357] Key type id_legacy registered
[    7.646370] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.646389] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    8.734237] NET: Registered protocol family 38
[    8.793780] Key type asymmetric registered
[    8.793790] Asymmetric key parser 'x509' registered
[    8.793838] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    8.793850] io scheduler noop registered
[    8.793857] io scheduler deadline registered
[    8.793901] io scheduler cfq registered (default)
[    8.793910] io scheduler mq-deadline registered
[    8.793917] io scheduler kyber registered
[    8.795728] xilinx-frmbuf a0010000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.795783] xilinx-frmbuf a02b0000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.795832] xilinx-frmbuf a02c0000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.795886] xilinx-frmbuf a0040000.v_frmbuf_rd: Probe deferred due to GPIO reset defer
[    8.822337] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    8.826570] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    8.831204] brd: module loaded
[    8.835092] loop: module loaded
[    8.836171] mtdoops: mtd device (mtddev=name/number) must be supplied
[    8.837513] libphy: Fixed MDIO Bus: probed
[    8.838722] tun: Universal TUN/TAP device driver, 1.6
[    8.839241] CAN device driver interface
[    8.840413] xilinx_axienet b0001000.ethernet: missing/invalid xlnx,addrwidth property, using default
[    8.840476] xilinx_axienet b0001000.ethernet: Ethernet clock init failed -517
[    8.841028] usbcore: registered new interface driver asix
[    8.841077] usbcore: registered new interface driver ax88179_178a
[    8.841109] usbcore: registered new interface driver cdc_ether
[    8.841139] usbcore: registered new interface driver net1080
[    8.841170] usbcore: registered new interface driver cdc_subset
[    8.841200] usbcore: registered new interface driver zaurus
[    8.841247] usbcore: registered new interface driver cdc_ncm
[    8.841799] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.841809] ehci-pci: EHCI PCI platform driver
[    8.842152] usbcore: registered new interface driver uas
[    8.842191] usbcore: registered new interface driver usb-storage
[    8.843400] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    8.843478] i2c /dev entries driver
[    8.844357] si5324 0-0068: si5319 probed
[    8.917499] si5324 0-0068: si5319 probe successful
[    8.917907] xilinx-video amba_pl@0:vcap_hdmi: /amba_pl@0/vcap_hdmi/ports/port@0 initialization failed
[    8.917921] xilinx-video amba_pl@0:vcap_hdmi: DMA initialization failed
[    8.919399] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[    8.919413] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[    8.919689] usbcore: registered new interface driver uvcvideo
[    8.919698] USB Video Class driver (1.1.1)
[    8.921299] Bluetooth: HCI UART driver ver 2.3
[    8.921312] Bluetooth: HCI UART protocol H4 registered
[    8.921320] Bluetooth: HCI UART protocol BCSP registered
[    8.921348] Bluetooth: HCI UART protocol LL registered
[    8.921357] Bluetooth: HCI UART protocol ATH3K registered
[    8.921381] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    8.921442] Bluetooth: HCI UART protocol Intel registered
[    8.921469] Bluetooth: HCI UART protocol QCA registered
[    8.921509] usbcore: registered new interface driver bcm203x
[    8.921543] usbcore: registered new interface driver bpa10x
[    8.921577] usbcore: registered new interface driver bfusb
[    8.921612] usbcore: registered new interface driver btusb
[    8.921621] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    8.921670] usbcore: registered new interface driver ath3k
[    8.921805] EDAC MC: ECC not enabled
[    8.921987] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    8.922711] sdhci: Secure Digital Host Controller Interface driver
[    8.922720] sdhci: Copyright(c) Pierre Ossman
[    8.922727] sdhci-pltfm: SDHCI platform and OF driver helper
[    8.923844] ledtrig-cpu: registered to indicate activity on CPUs
[    8.923901] zynqmp_firmware_probe Platform Management API v1.1
[    8.923912] zynqmp_firmware_probe Trustzone version v1.0
[    8.926707] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[    8.950348] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[    8.950875] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    8.950896] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    8.950896]
[    8.951088] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    8.951267] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    8.951493] usbcore: registered new interface driver usbhid
[    8.951502] usbhid: USB HID core driver
[    8.954024] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    8.954453] usbcore: registered new interface driver snd-usb-audio
[    8.955454] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    8.956000] Initializing XFRM netlink socket
[    8.956082] NET: Registered protocol family 10
[    8.956445] Segment Routing with IPv6
[    8.956535] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    8.956877] NET: Registered protocol family 17
[    8.956893] NET: Registered protocol family 15
[    8.956912] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    8.956964] can: controller area network core (rev 20170425 abi 9)
[    8.956997] NET: Registered protocol family 29
[    8.957006] can: raw protocol (rev 20170425)
[    8.957014] can: broadcast manager protocol (rev 20170425 t)
[    8.957023] can: netlink gateway (rev 20170425) max_hops=1
[    8.957085] Bluetooth: RFCOMM TTY layer initialized
[    8.957096] Bluetooth: RFCOMM socket layer initialized
[    8.957118] Bluetooth: RFCOMM ver 1.11
[    8.957129] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    8.957137] Bluetooth: BNEP filters: protocol multicast
[    8.957147] Bluetooth: BNEP socket layer initialized
[    8.957155] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.957165] Bluetooth: HIDP socket layer initialized
[    8.957278] 9pnet: Installing 9P2000 support
[    8.957301] Key type dns_resolver registered
[    8.957699] registered taskstats version 1
[    8.957707] Loading compiled-in X.509 certificates
[    8.958042] Btrfs loaded, crc32c=crc32c-generic
[    8.964882] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249375) is a xuartps
[   10.318121] console [ttyPS0] enabled
[   10.322888] of-fpga-region fpga-full: FPGA Region probed
[   10.329204] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[   10.335803] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[   10.342917] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[   10.350029] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[   10.357139] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[   10.364250] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[   10.371357] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[   10.378468] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[   10.385580] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[   10.392760] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[   10.399869] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[   10.406973] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[   10.414088] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[   10.421192] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[   10.428316] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[   10.435420] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[   10.442537] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[   10.449648] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.457109] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.465758] xilinx-frmbuf a02b0000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.473212] xilinx-frmbuf a02b0000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.481862] xilinx-frmbuf a02c0000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.489323] xilinx-frmbuf a02c0000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.497975] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV
[   10.505436] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.514142] xlnx-mixer a0070000.v_mix: vtc bridge property not present
[   10.520793] xlnx-mixer a0070000.v_mix: Xilinx Mixer driver probed success
[   10.527918] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[   10.537939] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[   10.548652] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[   10.556713] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[   10.565397] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.577864] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.590538] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[   10.600733] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[   10.607775] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   10.614386] [drm] No driver support for vblank timestamp query.
[   10.620368] xlnx-drm xlnx-drm.1: bound fd4a0000.zynqmp-display (ops 0xffffff8008bcf900)
[   11.707650] [drm] Cannot find any crtc or sizes
[   11.712415] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[   11.720525] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[   11.729542] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[   11.737429] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[   11.746395] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[   11.756846] scsi host0: ahci-ceva
[   11.760437] scsi host1: ahci-ceva
[   11.763894] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[   11.771811] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[   11.780436] m25p80 spi0.0: found n25q512a, expected m25p80
[   11.786322] m25p80 spi0.0: n25q512a (131072 Kbytes)
[   11.791222] 4 fixed-partitions partitions found on MTD device spi0.0
[   11.797570] Creating 4 MTD partitions on "spi0.0":
[   11.802364] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[   11.808569] 0x000000100000-0x000000600000 : "qspi-linux"
[   11.814281] 0x000000600000-0x000000620000 : "qspi-device-tree"
[   11.820503] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[   11.828386] macb ff0e0000.ethernet: Not enabling partial store and forward
[   11.835763] libphy: MACB_mii_bus: probed
[   11.844758] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[   11.857820] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:00:22:01)
[   11.867988] xilinx_axienet b0001000.ethernet: missing/invalid xlnx,addrwidth property, using default
[   11.877173] xilinx_axienet b0001000.ethernet: couldn't find phy i/f
[   11.884156] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[   11.890699] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[   11.897191] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[   11.903701] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[   11.911719] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[   11.917570] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[   11.925746] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.931243] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   11.939227] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[   11.948643] xhci-hcd xhci-hcd.0.auto: irq 60, io mem 0xfe200000
[   11.954777] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   11.963044] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.970274] usb usb1: Product: xHCI Host Controller
[   11.975148] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   11.981847] usb usb1: SerialNumber: xhci-hcd.0.auto
[   11.987001] hub 1-0:1.0: USB hub found
[   11.990769] hub 1-0:1.0: 1 port detected
[   11.994889] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   12.000381] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   12.008046] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[   12.014778] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   12.023046] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.030264] usb usb2: Product: xHCI Host Controller
[   12.035139] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   12.041841] usb usb2: SerialNumber: xhci-hcd.0.auto
[   12.046957] hub 2-0:1.0: USB hub found
[   12.050726] hub 2-0:1.0: 1 port detected
[   12.055799] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[   12.063055] pca953x 1-0020: Linked as a consumer to regulator.0
[   12.069930] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[   12.077188] pca953x 1-0021: Linked as a consumer to regulator.0
[   12.084509] ina2xx 4-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.091303] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.092781] ata2: SATA link down (SStatus 0 SControl 330)
[   12.098099] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.103139] ata1: SATA link down (SStatus 0 SControl 330)
[   12.109842] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.121591] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.128383] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.135175] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.141965] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.148751] ina2xx 4-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.155541] ina2xx 4-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.161924] i2c i2c-1: Added multiplexed i2c bus 4
[   12.167351] ina2xx 5-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[   12.174145] ina2xx 5-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.180936] ina2xx 5-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.187735] ina2xx 5-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.194528] ina2xx 5-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.201323] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.208112] ina2xx 5-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.214904] ina2xx 5-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.221292] i2c i2c-1: Added multiplexed i2c bus 5
[   12.236078] random: fast init done
[   12.263480] i2c i2c-1: Added multiplexed i2c bus 6
[   12.268409] i2c i2c-1: Added multiplexed i2c bus 7
[   12.273201] pca954x 1-0075: registered 4 multiplexed busses for I2C mux pca9544
[   12.280533] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[   12.288268] at24 8-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[   12.295000] i2c i2c-2: Added multiplexed i2c bus 8
[   12.299992] i2c i2c-2: Added multiplexed i2c bus 9
[   12.304919] i2c i2c-2: Added multiplexed i2c bus 10
[   12.309919] i2c i2c-2: Added multiplexed i2c bus 11
[   12.315000] si5324 12-0069: si5328 probed
[   12.377544] si5324 12-0069: si5328 probe successful
[   12.382450] i2c i2c-2: Added multiplexed i2c bus 12
[   12.387541] i2c i2c-2: Added multiplexed i2c bus 13
[   12.392543] i2c i2c-2: Added multiplexed i2c bus 14
[   12.397538] i2c i2c-2: Added multiplexed i2c bus 15
[   12.402414] pca954x 2-0074: registered 8 multiplexed busses for I2C switch pca9548
[   12.410328] i2c i2c-2: Added multiplexed i2c bus 16
[   12.415335] i2c i2c-2: Added multiplexed i2c bus 17
[   12.420342] i2c i2c-2: Added multiplexed i2c bus 18
[   12.425730] i2c i2c-2: Added multiplexed i2c bus 19
[   12.430736] i2c i2c-2: Added multiplexed i2c bus 20
[   12.435752] i2c i2c-2: Added multiplexed i2c bus 21
[   12.440771] i2c i2c-2: Added multiplexed i2c bus 22
[   12.445777] i2c i2c-2: Added multiplexed i2c bus 23
[   12.450653] pca954x 2-0075: registered 8 multiplexed busses for I2C switch pca9548
[   12.458246] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[   12.464514] xilinx-video amba_pl@0:vcap_hdmi: device registered
[   12.470628] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[   12.480803] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[   12.489303] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0080000.v_proc_ss was not initialized!
[   12.499128] xilinx-vpss-scaler a0080000.v_proc_ss: Num Hori Taps 8
[   12.505303] xilinx-vpss-scaler a0080000.v_proc_ss: Num Vert Taps 8
[   12.511483] xilinx-vpss-scaler a0080000.v_proc_ss: VPSS Scaler Probe Successful
[   12.519219] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[   12.528425] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
[   12.537677] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[   12.545127] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[   12.583641] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[   12.599764] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   12.606807] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-07-12 15:36:24 UTC (1562945784)
[   12.615688] of_cfs_init
[   12.618135] of_cfs_init: OK
[   12.621120] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.662142] mmc0: new high speed SDHC card at address 0260
[   12.668184] mmcblk0: mmc0:0260 SD    3.77 GiB
[   12.674499]  mmcblk0: p1
[   12.765493] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.772033] clk: Not disabling unused clocks
[   12.776306] ALSA device list:
[   12.779263]   #0: DisplayPort monitor
[   12.783229] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   12.791842] cfg80211: failed to load regulatory.db
[   12.796911] Freeing unused kernel memory: 832K
[   12.831660] Run /init as init process
INIT: version 2.88 booting
[   12.887679] [drm] Cannot find any crtc or sizes
[   12.995934] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting udev
[   13.040268] udevd[2007]: starting version 3.2.5
[   13.045091] random: udevd: uninitialized urandom read (16 bytes read)
[   13.051587] random: udevd: uninitialized urandom read (16 bytes read)
[   13.058082] random: udevd: uninitialized urandom read (16 bytes read)
[   13.069544] udevd[2008]: starting eudev-3.2.5
[   13.140426] mali: loading out-of-tree module taints kernel.
[   13.189436] xilinx-vphy a0060000.vid_phy_controller: probed
[   13.196816] dp159 0-005e: probed
[   13.201666] dp159 0-005e: probe successful
[   13.213265] VPhy version : 02.02 (0000)
[   13.237035] xilinx-vphy a0060000.vid_phy_controller: probe successful
[   13.248146] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probed
[   13.253702] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: hdmi tx audio disabled in DT
[   13.254083] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probed
[   13.260893] xvphy_phy_init((____ptrval____)).
[   13.270584] xvphy_phy_init((____ptrval____)).
[   13.274991] xvphy_phy_init((____ptrval____)).
[   13.295362] hdmirx_irq_handler(): HDMI RX SS is not initialized?!
[   13.295531] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: Using 2 EDID blocks (256 bytes) from 'xilinx/xilinx-hdmi-rx-edid.bin'.
[   13.309194] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probe successful
[   13.312474]
[   13.312474] Successfully loaded edid.
[   13.321076] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   13.323813] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0000000.v_hdmi_rx_ss was not initialized!
[   13.330420] [drm] No driver support for vblank timestamp query.
[   13.342045] Not sending HOTPLUG event because drm device is NULL as drm_connector_init is not called yet.
[   13.344033] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probe successful
[   13.346635] xlnx-drm xlnx-drm.0: bound a0070000.v_mix (ops 0xffffff8008bcbae8)
[   13.369526] xlnx-drm xlnx-drm.0: bound a0020000.v_hdmi_tx_ss (ops xlnx_drm_hdmi_component_ops [xilinx_hdmi_tx])
[   13.461083] Console: switching to colour frame buffer device 240x75
[   13.501434] xlnx-mixer a0070000.v_mix: fb0:  frame buffer device
[   13.532038] [drm] Initialized xlnx 1.0.0 20130509 for a0070000.v_mix on minor 1
[   13.608711] xilinx-vcu xilinx-vcu: Could not get core_enc clock
[   13.615269] VCU PLL: enable
[   15.618143] VCU PLL is not locked
[   15.621613] xilinx-vcu xilinx-vcu: failed to enable mcu_enc -110
[   15.627762] xilinx-vcu xilinx-vcu: Failed to set the pll
[   15.633200] xilinx-vcu: probe of xilinx-vcu failed with error -110
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-libmali-xlnx...
/usr/sbin/run-postinsts: line 70: update-alternatives:: command not found
Running postinst /etc/rpm-postinsts/101-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [   16.160782] pps pps0: new PPS source ptp0
[   16.164905] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   16.171763] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.29.2
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting system message bus: dbus.
Starting Xserver
Starting Dropbear SSH server:
Generating 2048 bit rsa key, this may take a while...
X.Org X Server 1.20.1
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.10.0-693.el7.x86_64 x86_64
Current Operating System: Linux zcu106_vcu_trd 4.19.0-xilinx-v2019.1 #1 SMP Wed Jul 10 14:01:49 UTC 2019 aarch64
Build Date: 10 July 2019  02:05:38PM
Current version of pixman: 0.34.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 12 15:36:36 2019
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCHvyy/rBRcnf8R+yGouzhhniZCZ/4nIL372YRn4ruVgmlCZa+X0Y6CA5qNCKaezaZbA37M2Rz+y4Pl/nClGqsTd+/7sPaSYPUQcl+AYwJK/gGcP83E0kWS6apWUg2GtrpgLDWqW+xF7LVNjEyFnpj7bAhQEOb87D1QJODQX0hcRJOIvEiVlZIx/5kzd3ecqFfXHYo+XA6szoUM7gA6OHe08MKk4rkAsCnVoNcAWBxwsUpl0VeCq/NzbW5BlsJBq4DVc8A05IQYIaGRz8PbO9IxqGq+Fsn3q30+rd176YS1Gg+9kf2H5w3m38cmwZ+UpIan2VnAkdYx8SzAValrYMoj root@zcu106_vcu_trd
Fingerprint: sha1!! 33:a2:92:12:ad:ca:16:d9:b2:e1:80:fc:3b:d4:70:50:f0:03:6c:89
dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
net.core.rmem_default = 60000000
net.core.rmem_max = 60000000
net.core.wmem_default = 60000000
net.core.wmem_max = 60000000
failed to find mode "3840x2160" for connector 40
failed to create dumb buffer: Invalid argument
root@zcu106_vcu_trd:~# The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Unsupported high keycode 372 for name <I372> ignored
>                   X11 cannot support keycodes above 255.
>                   This warning only shows for the first high keycode.
Errors from xkbcomp are not fatal to the X server
D-BUS per-session daemon address is: unix:abstract=/tmp/dbus-UPiV8ouVOi,guid=9d3cbdc208040eb746de4f875d28a907
Failed to launch bus: Failed to execute child process ?/usr/bin? (Permission denied)Error: No calibratable devices found.
matchbox: Cant find a keycode for keysym 269025056
matchbox: ignoring key shortcut XF86Calendar=!$contacts
matchbox: Cant find a keycode for keysym 2809
matchbox: ignoring key shortcut telephone=!$dates
matchbox: Cant find a keycode for keysym 269025050
matchbox: ignoring key shortcut XF86Start=!matchbox-remote -desktop
[settings daemon] Forking. run with -n to prevent fork
(matchbox-desktop:2753): dbind-WARNING **: 15:36:39.318: Error retrieving accessibility bus address: org.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
(matchbox-panel:2754): dbind-WARNING **: 15:36:39.331: Error retrieving accessibility bus address: org.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
[   43.896219] random: crng init done
[   43.899614] random: 7 urandom warning(s) missed due to ratelimiting
driver          xilinx-video
serial
bus info
hw revision     0x0
Device topology
        pad0: Sink
        pad0: Sink
        pad1: Source
        pad0: Source
Driver Info:
                Streaming
                Extended Pix Format
                Device Capabilities
                Streaming
                Extended Pix Format
Media Driver Info:
        Serial           :
        Bus info         :
Interface Info:
        Type             : V4L Video
Entity Info:
        Function         : V4L2 I/O
Priority: 2
        Field             : None
        Flags             :
        Colorspace        : sRGB
root@zcu106_vcu_trd:~# xmedia-ctl -d /dev/media0 "a0080000.v_proc_ss":1 [fmt:VYY
root@zcu106_vcu_trd:~# xmedia-ctl -d /dev/media0 "a0080000.v_proc_ss":0 [fmt:RBG
Pipeline Info : On
Fps Info : Off
APM Info : On
Frame rate : 60
B Frames : 0
Bitrate : 60000
Enc Name : HEVC
Gop Len : 60
Profile : Main
Qp Mode : Auto
Rc Mode : CBR
Num Slice : 8
GoP Mode : Basic
Filler Data : True
Device Type : HDMI
Format : NV12
Width : 1920
Height : 1080
Raw : False
Src Type : Live Src
NOTE : Now I have no image on the HDMI_Tx (because the 1080p60 is not supported by the screen and need to be changed to 1024x768-60@BG24).
I still see the contradicition on the output of xmedia-ctl -p -d /dev/media0
BTW is there a way to ignore the HDMI_Tx and send the HDMI_rx (4k60) to the 10G interface (direct stream out) ?
Any other suggestions are more than welcome.
Best regards.
Scholar watari
Hi @ahmed_barco
Here is my understanding. Is it correct ?
# What you want to do
- Input : HDMI Rx (1024x768@BG24)
- Output : HDMI Tx (1024x768@BG24) and Ethernet by gstreamer or something
If yes, would you execute the following commands to make sure the relationship ?
I only use VCU_TRS (vcu_trd). So, I don't know the relationship of /dev/mediaX and /dev/videoX between each IP (HDMI Tx/Rx, VCU and so on)
$ ls /dev/video*
$ ls /dev/media*
$ xmedia-ctl -p -d /dev/mediaX (X: 0 to number of media devices -1)
Also, even if I can refer device tree of VCU TRD, but I'd like to share this information, would you upload your device tree file ?
In this case, you must correctly set a property on V4L2 bus (include media bus), color space, bus width, color depth, resolution and CRTC value.
After confirmation of your current setting on V4L2 bus, I will tell you suitable setting.
# Note
1)
At least, it seems /dev/media0 is not related with what you want to do.
So, I think that you need to find correct V4L2 path.
2)
If you want to debug "vcu_gst_app", I suggest you to use environment values of GST_DEBUG and GST_DEBUG_FILE.
This is tips for debugging of gstreamer. (include vcu_gst_app)
ex)
$ GST_DEBUG=ERROR,WARNING,FIXME,INFO GST_DEBUG_FILE=./gst_debug_log.txt vcu_gst_app <configuration file>
You can choose parameters of GST_DEBUG from the followings.
ERROR
WARNING
FIXME
INFO
DEBUG
LOG
TRACE
MEMDUMP
3)
If you want to know the status of HDMI Rx, I suggest you to execute the following commands.
$ cat /sys/devices/platform/amba_pl@0/<your hdmi rx ss name>hdmi_info
$ cat /sys/devices/platform/amba_pl@0/<your hdmi rx ss name>hdmi_log
Best regards,
Visitor ahmed_barco
Hello @watari
to answer your questions :
I am trying to stream ANY kind of HDMI (up to 4k) input using the 10G interface without displaying it.
my setup is : laptop (up to 3840x2160p60)  --> HDMI_rx --> 10G ethernet using Gstreamer AND a monitor conntected to HDMI_tx
what's happening :
  • The HDMI_rx seems to work fine since I can see the info and confirm that there is a link
  • The HDMI_tx is not able to output 1920x1080p60 to the monitor; In fact only 1027x768, 800x600 and 640x480 resolutions are OK. If I choose one of the rest the monitor is not displaying anything.
  • the 10G interface is not up. Probably because the Gstreamer is not running in first place
==> I think the most critical error is this : Couldnt allocate dma allocator (tried using /dev/allegroIP).
# Terminal output :
PMUFW:  v1.1
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu7ev
OK
In:    serial@ff000000
Manufacturer ID: 74
OEM: 4a45
Bus Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.8 GiB
Bus Width: 4-bit
166829940 bytes read in 10842 ms (14.7 MiB/s)
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    sha1
     Type:         RAMDisk Image
     OS:           Linux
     Hash algo:    sha1
     Hash algo:    sha1
Starting kernel ...
[    0.008287] Console: colour dummy device 80x25
[    0.019785] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.019803] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.020530] ASID allocator initialised with 32768 entries
[    0.020583] rcu: Hierarchical SRCU implementation.
[    0.020941] EFI services will not be available.
[    0.021062] smp: Bringing up secondary CPUs ...
[    0.021340] Detected VIPT I-cache on CPU1
[    0.021370] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.021679] Detected VIPT I-cache on CPU2
[    0.021698] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.021985] Detected VIPT I-cache on CPU3
[    0.022004] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.022048] smp: Brought up 1 node, 4 CPUs
[    0.022082] SMP: Total of 4 processors activated.
[    0.022090] CPU features: detected: 32-bit EL0 Support
[    0.023629] CPU: All CPU(s) started at EL2
[    0.023661] alternatives: patching kernel code
[    0.024538] devtmpfs: initialized
[    0.030194] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030218] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.066128] xor: measuring software checksum speed
[    0.103838]    8regs     :  2375.000 MB/sec
[    0.143863]    8regs_prefetch:  2052.000 MB/sec
[    0.183894]    32regs    :  2724.000 MB/sec
[    0.223923]    32regs_prefetch:  2308.000 MB/sec
[    0.223931] xor: using function: 32regs (2724.000 MB/sec)
[    0.223946] pinctrl core: initialized pinctrl subsystem
[    0.224588] NET: Registered protocol family 16
[    0.224865] audit: initializing netlink subsys (disabled)
[    0.224952] audit: type=2000 audit(0.216:1): state=initialized audit_enabled=0 res=1
[    0.225335] cpuidle: using governor menu
[    0.225464] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.225477] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.226181] DMA: preallocated 256 KiB pool for atomic allocations
[    0.241517] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.308096] raid6: int64x1  gen()   445 MB/s
[    0.376129] raid6: int64x1  xor()   454 MB/s
[    0.444222] raid6: int64x2  gen()   681 MB/s
[    0.512221] raid6: int64x2  xor()   599 MB/s
[    0.580247] raid6: int64x4  gen()   981 MB/s
[    0.648327] raid6: int64x4  xor()   736 MB/s
[    0.716361] raid6: int64x8  gen()  1163 MB/s
[    0.784394] raid6: int64x8  xor()   759 MB/s
[    0.852523] raid6: neonx1   gen()   735 MB/s
[    0.920526] raid6: neonx1   xor()   879 MB/s
[    0.988596] raid6: neonx2   gen()  1128 MB/s
[    1.056619] raid6: neonx2   xor()  1172 MB/s
[    1.124696] raid6: neonx4   gen()  1477 MB/s
[    1.192724] raid6: neonx4   xor()  1417 MB/s
[    1.260797] raid6: neonx8   gen()  1529 MB/s
[    1.328823] raid6: neonx8   xor()  1460 MB/s
[    1.328831] raid6: using algorithm neonx8 gen() 1529 MB/s
[    1.328838] raid6: .... xor() 1460 MB/s, rmw enabled
[    1.328846] raid6: using neon recovery algorithm
[    1.329669] SCSI subsystem initialized
[    1.329879] usbcore: registered new interface driver usbfs
[    1.329920] usbcore: registered new interface driver hub
[    1.329962] usbcore: registered new device driver usb
[    1.330030] media: Linux media interface: v0.10
[    1.330059] videodev: Linux video capture interface: v2.00
[    1.330091] pps_core: LinuxPPS API ver. 1 registered
[    1.330099] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.330122] PTP clock support registered
[    1.330154] EDAC MC: Ver: 3.0.0
[    1.330785] FPGA manager framework
[    1.330960] Advanced Linux Sound Architecture Driver Initialized.
[    1.331238] Bluetooth: Core ver 2.22
[    1.331266] NET: Registered protocol family 31
[    1.331274] Bluetooth: HCI device and connection manager initialized
[    1.331286] Bluetooth: HCI socket layer initialized
[    1.331296] Bluetooth: L2CAP socket layer initialized
[    1.331319] Bluetooth: SCO socket layer initialized
[    1.331632] clocksource: Switched to clocksource arch_sys_counter
[    1.331708] VFS: Disk quotas dquot_6.6.0
[    1.331754] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.336172] NET: Registered protocol family 2
[    1.336538] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[    1.336589] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.336797] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    1.337205] TCP: Hash tables configured (established 32768 bind 32768)
[    1.337273] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337351] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    1.337507] NET: Registered protocol family 1
[    1.337721] RPC: Registered named UNIX socket transport module.
[    1.337730] RPC: Registered udp transport module.
[    1.337737] RPC: Registered tcp transport module.
[    1.337744] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.338074] Trying to unpack rootfs image as initramfs...
[    7.643713] Freeing initrd memory: 145072K
[    7.644141] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    7.644311] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    7.645326] Initialise system trusted keyrings
[    7.645423] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[    7.646160] NFS: Registering the id_resolver key type
[    7.646179] Key type id_resolver registered
[    7.646186] Key type id_legacy registered
[    7.646199] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.646219] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    8.734017] NET: Registered protocol family 38
[    8.795145] Key type asymmetric registered
[    8.795155] Asymmetric key parser 'x509' registered
[    8.795201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    8.795214] io scheduler noop registered
[    8.795221] io scheduler deadline registered
[    8.795266] io scheduler cfq registered (default)
[    8.795275] io scheduler mq-deadline registered
[    8.795282] io scheduler kyber registered
[    8.797098] xilinx-frmbuf a0010000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.797151] xilinx-frmbuf a02b0000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.797200] xilinx-frmbuf a02c0000.v_frmbuf_wr: Probe deferred due to GPIO reset defer
[    8.797254] xilinx-frmbuf a0040000.v_frmbuf_rd: Probe deferred due to GPIO reset defer
[    8.823756] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    8.827921] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    8.832521] brd: module loaded
[    8.836446] loop: module loaded
[    8.837483] mtdoops: mtd device (mtddev=name/number) must be supplied
[    8.838824] libphy: Fixed MDIO Bus: probed
[    8.840063] tun: Universal TUN/TAP device driver, 1.6
[    8.840529] CAN device driver interface
[    8.841642] xilinx_axienet b0001000.ethernet: missing/invalid xlnx,addrwidth property, using default
[    8.841698] xilinx_axienet b0001000.ethernet: Ethernet clock init failed -517
[    8.841961] usbcore: registered new interface driver asix
[    8.842000] usbcore: registered new interface driver ax88179_178a
[    8.842032] usbcore: registered new interface driver cdc_ether
[    8.842061] usbcore: registered new interface driver net1080
[    8.842091] usbcore: registered new interface driver cdc_subset
[    8.842124] usbcore: registered new interface driver zaurus
[    8.842164] usbcore: registered new interface driver cdc_ncm
[    8.842789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.842799] ehci-pci: EHCI PCI platform driver
[    8.843143] usbcore: registered new interface driver uas
[    8.843185] usbcore: registered new interface driver usb-storage
[    8.843768] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    8.843850] i2c /dev entries driver
[    8.844417] si5324 0-0068: si5319 probed
[    8.913508] si5324 0-0068: si5319 probe successful
[    8.913948] xilinx-video amba_pl@0:vcap_hdmi: /amba_pl@0/vcap_hdmi/ports/port@0 initialization failed
[    8.913962] xilinx-video amba_pl@0:vcap_hdmi: DMA initialization failed
[    8.915476] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[    8.915491] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[    8.915779] usbcore: registered new interface driver uvcvideo
[    8.915788] USB Video Class driver (1.1.1)
[    8.916427] Bluetooth: HCI UART driver ver 2.3
[    8.916439] Bluetooth: HCI UART protocol H4 registered
[    8.916447] Bluetooth: HCI UART protocol BCSP registered
[    8.916474] Bluetooth: HCI UART protocol LL registered
[    8.916482] Bluetooth: HCI UART protocol ATH3K registered
[    8.916505] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    8.916556] Bluetooth: HCI UART protocol Intel registered
[    8.916580] Bluetooth: HCI UART protocol QCA registered
[    8.916620] usbcore: registered new interface driver bcm203x
[    8.916656] usbcore: registered new interface driver bpa10x
[    8.916693] usbcore: registered new interface driver bfusb
[    8.916728] usbcore: registered new interface driver btusb
[    8.916737] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    8.916794] usbcore: registered new interface driver ath3k
[    8.916927] EDAC MC: ECC not enabled
[    8.917162] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    8.917890] sdhci: Secure Digital Host Controller Interface driver
[    8.917899] sdhci: Copyright(c) Pierre Ossman
[    8.917906] sdhci-pltfm: SDHCI platform and OF driver helper
[    8.918280] ledtrig-cpu: registered to indicate activity on CPUs
[    8.918330] zynqmp_firmware_probe Platform Management API v1.1
[    8.918340] zynqmp_firmware_probe Trustzone version v1.0
[    8.921172] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[    8.944891] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[    8.945420] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    8.945441] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    8.945441]
[    8.945638] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    8.945821] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    8.946046] usbcore: registered new interface driver usbhid
[    8.946055] usbhid: USB HID core driver
[    8.948585] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    8.949019] usbcore: registered new interface driver snd-usb-audio
[    8.950028] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    8.950406] Initializing XFRM netlink socket
[    8.950485] NET: Registered protocol family 10
[    8.950857] Segment Routing with IPv6
[    8.950948] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    8.951281] NET: Registered protocol family 17
[    8.951297] NET: Registered protocol family 15
[    8.951316] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    8.951355] can: controller area network core (rev 20170425 abi 9)
[    8.951386] NET: Registered protocol family 29
[    8.951395] can: raw protocol (rev 20170425)
[    8.951403] can: broadcast manager protocol (rev 20170425 t)
[    8.951413] can: netlink gateway (rev 20170425) max_hops=1
[    8.951711] Bluetooth: RFCOMM TTY layer initialized
[    8.951725] Bluetooth: RFCOMM socket layer initialized
[    8.951745] Bluetooth: RFCOMM ver 1.11
[    8.951757] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    8.951765] Bluetooth: BNEP filters: protocol multicast
[    8.951775] Bluetooth: BNEP socket layer initialized
[    8.951783] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.951793] Bluetooth: HIDP socket layer initialized
[    8.951912] 9pnet: Installing 9P2000 support
[    8.951932] Key type dns_resolver registered
[    8.952332] registered taskstats version 1
[    8.952340] Loading compiled-in X.509 certificates
[    8.952680] Btrfs loaded, crc32c=crc32c-generic
[    8.959567] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249375) is a xuartps
[   10.312849] console [ttyPS0] enabled
[   10.317612] of-fpga-region fpga-full: FPGA Region probed
[   10.323826] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[   10.330420] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[   10.337531] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[   10.344644] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[   10.351761] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[   10.358875] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[   10.365989] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[   10.373103] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[   10.380213] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[   10.387390] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[   10.394499] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[   10.401608] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[   10.408723] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[   10.415838] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[   10.422948] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[   10.430056] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[   10.437171] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[   10.444283] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.451744] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.460391] xilinx-frmbuf a02b0000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.467842] xilinx-frmbuf a02b0000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.476496] xilinx-frmbuf a02c0000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[   10.483956] xilinx-frmbuf a02c0000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.492606] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV
[   10.500059] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!!
[   10.508763] xlnx-mixer a0070000.v_mix: vtc bridge property not present
[   10.515416] xlnx-mixer a0070000.v_mix: Xilinx Mixer driver probed success
[   10.522535] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[   10.532555] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[   10.543255] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[   10.551306] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[   10.559943] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.572402] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[   10.585091] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[   10.595278] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[   10.602310] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   10.608923] [drm] No driver support for vblank timestamp query.
[   10.614909] xlnx-drm xlnx-drm.1: bound fd4a0000.zynqmp-display (ops 0xffffff8008bcf900)
[   11.699646] [drm] Cannot find any crtc or sizes
[   11.704417] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[   11.712528] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[   11.721522] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[   11.729414] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[   11.738380] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[   11.748861] scsi host0: ahci-ceva
[   11.752446] scsi host1: ahci-ceva
[   11.755911] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 40
[   11.763830] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 40
[   11.772462] m25p80 spi0.0: found n25q512a, expected m25p80
[   11.778461] m25p80 spi0.0: n25q512a (131072 Kbytes)
[   11.783363] 4 fixed-partitions partitions found on MTD device spi0.0
[   11.789711] Creating 4 MTD partitions on "spi0.0":
[   11.794503] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[   11.800719] 0x000000100000-0x000000600000 : "qspi-linux"
[   11.806425] 0x000000600000-0x000000620000 : "qspi-device-tree"
[   11.812643] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[   11.820518] macb ff0e0000.ethernet: Not enabling partial store and forward
[   11.827894] libphy: MACB_mii_bus: probed
[   11.836919] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[   11.849970] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 30 (00:0a:35:05:08:4a)
[   11.860130] xilinx_axienet b0001000.ethernet: missing/invalid xlnx,addrwidth property, using default
[   11.869312] xilinx_axienet b0001000.ethernet: couldn't find phy i/f
[   11.876294] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[   11.882839] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[   11.889330] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[   11.895826] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[   11.903851] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[   11.909704] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[   11.917863] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.923357] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   11.931345] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[   11.940758] xhci-hcd xhci-hcd.0.auto: irq 60, io mem 0xfe200000
[   11.946892] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   11.955159] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.962380] usb usb1: Product: xHCI Host Controller
[   11.967254] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   11.973954] usb usb1: SerialNumber: xhci-hcd.0.auto
[   11.979110] hub 1-0:1.0: USB hub found
[   11.982883] hub 1-0:1.0: 1 port detected
[   11.987000] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.992488] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   12.000153] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
[   12.006884] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   12.015151] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.022369] usb usb2: Product: xHCI Host Controller
[   12.027244] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[   12.033938] usb usb2: SerialNumber: xhci-hcd.0.auto
[   12.039047] hub 2-0:1.0: USB hub found
[   12.042813] hub 2-0:1.0: 1 port detected
[   12.047893] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[   12.055146] pca953x 1-0020: Linked as a consumer to regulator.0
[   12.061798] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[   12.069049] pca953x 1-0021: Linked as a consumer to regulator.0
[   12.076369] ina2xx 4-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.083157] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.085854] ata1: SATA link down (SStatus 0 SControl 330)
[   12.094940] ata2: SATA link down (SStatus 0 SControl 330)
[   12.095105] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.107132] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.113921] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.120714] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.127508] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.134296] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.141081] ina2xx 4-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.147881] ina2xx 4-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.154262] i2c i2c-1: Added multiplexed i2c bus 4
[   12.159690] ina2xx 5-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[   12.166483] ina2xx 5-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.173271] ina2xx 5-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.180071] ina2xx 5-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.186865] ina2xx 5-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.193659] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.200457] ina2xx 5-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.207253] ina2xx 5-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   12.213641] i2c i2c-1: Added multiplexed i2c bus 5
[   12.228975] random: fast init done
[   12.255554] i2c i2c-1: Added multiplexed i2c bus 6
[   12.260477] i2c i2c-1: Added multiplexed i2c bus 7
[   12.265271] pca954x 1-0075: registered 4 multiplexed busses for I2C mux pca9544
[   12.272605] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 32
[   12.280310] at24 8-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[   12.287045] i2c i2c-2: Added multiplexed i2c bus 8
[   12.292038] i2c i2c-2: Added multiplexed i2c bus 9
[   12.296965] i2c i2c-2: Added multiplexed i2c bus 10
[   12.301968] i2c i2c-2: Added multiplexed i2c bus 11
[   12.307048] si5324 12-0069: si5328 probed
[   12.373476] si5324 12-0069: si5328 probe successful
[   12.378387] i2c i2c-2: Added multiplexed i2c bus 12
[   12.383481] i2c i2c-2: Added multiplexed i2c bus 13
[   12.388491] i2c i2c-2: Added multiplexed i2c bus 14
[   12.393492] i2c i2c-2: Added multiplexed i2c bus 15
[   12.398375] pca954x 2-0074: registered 8 multiplexed busses for I2C switch pca9548
[   12.406282] i2c i2c-2: Added multiplexed i2c bus 16
[   12.411289] i2c i2c-2: Added multiplexed i2c bus 17
[   12.416298] i2c i2c-2: Added multiplexed i2c bus 18
[   12.421685] i2c i2c-2: Added multiplexed i2c bus 19
[   12.426689] i2c i2c-2: Added multiplexed i2c bus 20
[   12.431710] i2c i2c-2: Added multiplexed i2c bus 21
[   12.436714] i2c i2c-2: Added multiplexed i2c bus 22
[   12.441725] i2c i2c-2: Added multiplexed i2c bus 23
[   12.446605] pca954x 2-0075: registered 8 multiplexed busses for I2C switch pca9548
[   12.454198] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[   12.460477] xilinx-video amba_pl@0:vcap_hdmi: device registered
[   12.466596] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[   12.476774] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[   12.485271] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0080000.v_proc_ss was not initialized!
[   12.495099] xilinx-vpss-scaler a0080000.v_proc_ss: Num Hori Taps 8
[   12.501273] xilinx-vpss-scaler a0080000.v_proc_ss: Num Vert Taps 8
[   12.507454] xilinx-vpss-scaler a0080000.v_proc_ss: VPSS Scaler Probe Successful
[   12.515190] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[   12.524393] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
[   12.533646] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[   12.541099] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[   12.579638] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[   12.595703] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   12.602754] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-07-13 14:12:42 UTC (1563027162)
[   12.611636] of_cfs_init
[   12.614087] of_cfs_init: OK
[   12.617041] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.658135] mmc0: new high speed SDHC card at address 0260
[   12.664176] mmcblk0: mmc0:0260 SD    3.77 GiB
[   12.670533]  mmcblk0: p1
[   12.761374] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.767907] clk: Not disabling unused clocks
[   12.772180] ALSA device list:
[   12.775137]   #0: DisplayPort monitor
[   12.779065] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   12.787681] cfg80211: failed to load regulatory.db
[   12.792750] Freeing unused kernel memory: 832K
[   12.811667] Run /init as init process
[   12.883668] [drm] Cannot find any crtc or sizes
Starting udev
[   13.143383] udevd[2008]: starting version 3.2.5
[   13.148253] random: udevd: uninitialized urandom read (16 bytes read)
[   13.154820] random: udevd: uninitialized urandom read (16 bytes read)
[   13.161318] random: udevd: uninitialized urandom read (16 bytes read)
[   13.172693] udevd[2009]: starting eudev-3.2.5
[   13.234652] mali: loading out-of-tree module taints kernel.
[   13.307128] xilinx-vphy a0060000.vid_phy_controller: probed
[   13.314472] dp159 0-005e: probed
[   13.324947] VPhy version : 02.02 (0000)
[   13.325205] dp159 0-005e: probe successful
[   13.342596] xilinx-vphy a0060000.vid_phy_controller: probe successful
[   13.353498] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probed
[   13.358822] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: hdmi tx audio disabled in DT
[   13.359144] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probed
[   13.366002] xvphy_phy_init((____ptrval____)).
[   13.375703] xvphy_phy_init((____ptrval____)).
[   13.380084] xvphy_phy_init((____ptrval____)).
[   13.386591] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probe successful
[   13.393829] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   13.394510] Not sending HOTPLUG event because drm device is NULL as drm_connector_init is not called yet.
[   13.400484] [drm] No driver support for vblank timestamp query.
[   13.400718] xlnx-drm xlnx-drm.0: bound a0070000.v_mix (ops 0xffffff8008bcbae8)
[   13.411010] hdmirx_irq_handler(): HDMI RX SS is not initialized?!
[   13.416127] xlnx-drm xlnx-drm.0: bound a0020000.v_hdmi_tx_ss (ops xlnx_drm_hdmi_component_ops [xilinx_hdmi_tx])
[   13.438189] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: Using 2 EDID blocks (256 bytes) from 'xilinx/xilinx-hdmi-rx-edid.bin'.
[   13.450485]
[   13.450485] Successfully loaded edid.
[   13.455847] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0000000.v_hdmi_rx_ss was not initialized!
[   13.467353] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probe successful
[   13.515613] Console: switching to colour frame buffer device 240x75
[   13.558226] xlnx-mixer a0070000.v_mix: fb0:  frame buffer device
[   13.592402] [drm] Initialized xlnx 1.0.0 20130509 for a0070000.v_mix on minor 1
[   13.641509] xilinx-vcu xilinx-vcu: Could not get core_enc clock
[   13.648819] VCU PLL: enable
[   15.651689] VCU PLL is not locked
[   15.655144] xilinx-vcu xilinx-vcu: failed to enable mcu_enc -110
[   15.661297] xilinx-vcu xilinx-vcu: Failed to set the pll
[   15.666759] xilinx-vcu: probe of xilinx-vcu failed with error -110
Configuring network interfaces... [   16.175091] pps pps0: new PPS source ptp0
[   16.179240] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[   16.186095] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
done.
Starting Xserver
Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 13 14:12:54 2019
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCL6fzUApvrJw1KFwREJr6VaCKD/tNvi2fqkGaSxsQTmO1mrbf0qSogGqBTdCgviEqjnimWOZRvWPTLab5tduUd9UVDBugzmyZOjmxXsNXfksQJKpyT6ihJ6B3a8E1eoKem9OpqwlJDfw01Y4Hs30yhokHSbuCj7501P2j7RjOr91i6eM+G9YEXd5vCEjQHhp+PVXigYwNZ69lPgA8V7K4+5WTleT8NSOguAHANTTZodaYYwkcYE09lsKGAvsdXHlJJxXpU6xohpanNVnfY8GdqHPcBGtFMyvS/sIqAL5C73UTIOorSyk/Ci6k3+gr6A3V0MlPheSIot0+FMNrjc+ox root@zcu106_vcu_trd
Fingerprint: sha1!! 1a:bc:22:93:d3:40:9b:6c:2d:8f:3b:02:e8:00:7d:52:40:2e:b7:24
dropbear.
Last login: Sat Jul 13 14:12:57 UTC 2019 on tty1
root@zcu106_vcu_trd:~# setting mode 1024x768-60Hz@BG24 on connectors 40, crtc 38
D-BUS per-session daemon address is: unix:abstract=/tmp/dbus-9GrUR4T7rQ,guid=4fb7ef8d84d6e11c04bb91fb5d29e6e9
Failed to launch bus: Failed to execute child process ?/usr/bin? [   27.890235] random: crng init done
[   27.894964] random: 7 urandom warning(s) missed due to ratelimiting
(matchbox-panel:2760): dbind-WARNING **: 14:12:57.607: Error retrieving accessibility bus address: org.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
(matchbox-desktop:2759): dbind-WARNING **: 14:12:57.607: Error retrieving accessibility bus address: org.a11y.Bus.Error: Failed to execute child process ?/usr/bin? (Permission denied)
root@zcu106_vcu_trd:~# ls /dev/video*
/dev/video0
root@zcu106_vcu_trd:~# ls /dev/media*
/dev/media0
root@zcu106_vcu_trd:~# xmedia-ctl -p -d /dev/media0
Media controller API version 4.19.0
Media device information
driver          xilinx-video
model           Xilinx Video Composite Device
serial
bus info
hw revision     0x0
driver version  4.19.0
Device topology
- entity 1: vcap_hdmi output 0 (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
                <- "a0080000.v_proc_ss":1 [ENABLED]
- entity 5: a0080000.v_proc_ss (2 pads, 2 links)
            type V4L2 subdev subtype Unknown flags 0
            device node name /dev/v4l-subdev0
        pad0: Sink
                [fmt:Y8_1X8/1280x720 field:none colorspace:srgb]
                <- "a0000000.v_hdmi_rx_ss":0 [ENABLED]
        pad1: Source
                [fmt:Y8_1X8/1920x1080 field:none colorspace:srgb]
                -> "vcap_hdmi output 0":0 [ENABLED]
- entity 8: a0000000.v_hdmi_rx_ss (1 pad, 1 link)
            device node name /dev/v4l-subdev1
        pad0: Source
                [fmt:RBG888_1X24/1920x1080 field:none colorspace:srgb]
                [dv.caps:BT.656/1120 min:0x0@25000000 max:4096x2160@297000000 stds:CEA-861,DMT,CVT,GTF caps:progressive,reduced-blanking,custom]
                [dv.detect:BT.656/1120 1920x1080p60 (2200x1125) stds:CEA-861 flags:CE-video]
                -> "a0080000.v_proc_ss":0 [ENABLED]
root@zcu106_vcu_trd:~# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/hdmi_info
  Stream Info
        Color Format:     RGB
        Color Depth:      8
        Pixels Per Clock: 2
        Mode:             Progressive
        Frame Rate:       60Hz
        Resolution:       1920x1080@60Hz
        Pixel Clock:      148500000
  Stream Timing
        HSYNC Timing: hav=1920, hfp=88, hsw=44(hsp=1), hbp=148, htot=2200
        VSYNC Timing: vav=1080, vfp=04, vsw=05(vsp=1), vbp=036, vtot=1125
Rx Info
Mode: HDMI
VIC : 16
Scrambled: 0
Audio
Format   : L-PCM
Channels : 2
ACR CTS  : 148500
ACR N    : 6144
Link quality
Link quality channel 0 : excellent (0)
Link quality channel 1 : excellent (0)
Link quality channel 2 : excellent (0)
root@zcu106_vcu_trd:~# cat /sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss/hdmi_log
HDMI RX log
Initializing HDMI RX core....
Reset HDMI RX Subsystem....
RX cable is connected....
RX TMDS reference clock change
RX Stream Init
RX mode changed to HDMI
RX Stream Start
RX Stream is Up
it confirms that the INPUT is OK but something is not working in the video processing ...
#  device tree file :
I am using the default image provided in rdf0428-zcu106-vcu-trd-2019-1_v2. I only regenerated the PL using vivado and didn't recompile the image (for now I don't have petalinux environement installed)
I will try to debug the Gstreamer up to see what might be a problem.
Looking forward to hear from you.
regards
Scholar watari
Re: VCU TRD (vcu_10G)
Hi @ahmed_barco
Here are the route causes.
1) You don't use suitable device tree file or set suitable parameter for internal PLL for VCU.
2) You don't set suitable parameters on V4L2 and mdedia bus in Linux OS by ex) xmedia-ctl.
3) You don't set suitable parameters to CRTC and an internal scaler by v4l2-ctl.
4) Might be a monitor issue. Would you share model name of your HDMI sink monitor ?
*1)
Make sure your building procedure whether is correct or not.
Also, make sure clock parameter setting for PLL.
*2)
Make sure whole V4L2 and media bus by ex. xmedial-ctl, v4l2-ctl, device tree blob file and so on.
At least the followings are not suitable setting.
Device topology
        pad0: Sink
        pad0: Sink
        pad1: Source
        pad0: Source
*3 and *4)
Would you make sure your HDMI monitor first ?
Does it support FHD@60p ? If yes, would you set suitable parameter to CRTC by v4l2-ctl ?
Would you refer Xilinx Wiki for this TRD ?
Best regards,
Visitor ahmed_barco
Hello @watari
To answer your questions :
1) I just generated the project using the tcl file provided in the Xilinx wiki page then I tested with the ready image files for the SD Card.
My monitor is Sony PremierPro SDM-P234
2) The EDID reader of the ref design doesn't reconize the FHD60p of the monitor :
root@zcu106_vcu_trd:~# modetest -M xlnx
Encoders:
id      crtc    type    possible crtcs  possible clones
39      38      TMDS    0x00000001      0x00000000
Connectors:
id      encoder status          name            size (mm)       modes   encoders
40      39      connected       HDMI-A-1        500x310         8       39
  modes:
        name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
  1920x1200 60 1920 1968 2000 2080 1200 1203 1209 1235 154000 flags: phsync, nvsync; type: preferred, driver
  1600x1200 60 1600 1664 1856 2160 1200 1201 1204 1250 162000 flags: phsync, pvsync; type: driver
  1280x1024 60 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver
  1280x960 60 1280 1376 1488 1800 960 961 964 1000 108000 flags: phsync, pvsync; type: driver
  1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
  800x600 60 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
  640x480 60 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
  720x400 70 720 738 846 900 400 412 414 449 28320 flags: nhsync, pvsync; type: driver
And if I set (using modetest -M xlnx -D a0070000.v_mix -s 40:1024x768-60@BG24) any resolution higher than 1024x768p60 the monitor doesn't display anything.
3) 4) The monitor (on windows) can be set to FHD60p :
But the resolution is not supported in the design for this monitor (therefore can't be set).
again I am following the Xilinx wiki page for the TRD but so far couldn't make it run.
Best regards
Scholar watari
Hi @ahmed_barco
Unfortunately, the route cause is using this monitor.
Here are reasons to occur this issue.
1) This monitor is old-fashioned. Only support DVI as digital interface. Not support HDMI.
2) Basically, an old-fashioned monitor which only support DVI as digital interface doesn't support CEA video timing.
3) Since there is not FHD@60Hz on supporting list in EDID, a graphics driver in Windows can't output FHD@60Hz in any officially supported.
Also, here are some solutions for you.
Would you choose it from the followings and try it ?
a) Change a monitor to supported FHD@60Hz. It's easy way to resolve this issue.
b) Modify EDID file in /lib/firmware/xilinx/Xilinx-hdmi-rx-edid.bin and use scaler function to change the resolution from 1920x1080 to 1920x1200. Unfortunately, an aspect ratio is broken.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841884/Xilinx+V4L2+hdmirx+driver
Describe 1920x1080@60Hz as detailed video timing and change other things without contradiction.
I'm sure that it's difficult for you if you are not an expert about this.
c) Create custom resolution by using ex. nvidia tool in nvidia control panel.
Best regards,
