VCU decode -> encode pipeline error - Driver bug detected
I need to post-process a previously encoded video file (using VCU, working with the 2018.3 tools version), for that I'm doing the next:
video file in -> decode -> process raw video -> encode back -> video file out
The gstreamer comand line:
gst-launch-1.0 filesrc location="input.ts" --gst-debug-level=2 ! tsdemux ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! v4l2video1convert capture-io-mode=4 output-io-mode=4 disable_passthrough=1 !  omxh264enc ! queue max-size-bytes=-1 ! h264parse ! mpegtsmux ! filesink location="output.ts"
The errors are:
0:00:00.103577456  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103693768  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103906720  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.103943460  2763      0xdc1fa30 ERROR                   v4l2 gstv4l2object.c:1910:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
Any ideas why I'm getting this errors?
Re: VCU decode -> encode pipeline error - Driver bug detected
Jus a quick update,
Using a USB3 memory I was able to get a video file decoded and encoded back again, not sure if this wil work with all video files but it seems to work better like this...
Mentor watari
Mentor
Hi @joseer
Where do I get plugin's source code of "v4l2video1convert" ?
If it is inhouse gstreamer's plugin, make sure the capability of it on source and sink side.
If other, make sure an identity of input.ts.
Hi @watari , thanks for your answer.
The v4l2video1convert plugin is generated by the mem2mem driver   framework as a response to the hardware  definition in the device tree. I did check the capabilities and everything looks ok.
I made some tests and in order to debug this better I simplified the pipeline and tried only to decode the file but the pipeline gets stuck:
Pipeline:
gst-launch-1.0 filesrc location="input.ts" --gst-debug-level=2 ! tsdemux ! h264parse ! queue ! omxh264dec ! queue ! video/x-raw, width=1280, height=1024, format=NV16 ! filesink location="output.yuv"
 And it gets stuck here:
Setting pipeline to PAUSED ...
0:00:00.064188882  2436   0x7f98002360 WARN                 basesrc gstbasesrc.c:3480:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
Redistribute latency...
0:00:00.255551476  2436   0x7f98004c50 WARN                GST_PADS gstpad.c:4109:gst_pad_peer_query:<omxh264dec-omxh264dec0:src> could not send sticky events
0:00:00.255689397  2436   0x7f98004c50 WARN            videodecoder gstvideodecoder.c:3797:gst_video_decoder_negotiate_pool:<omxh264dec-omxh264dec0> Subclass failed to decide allocation
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
The generated file is big (> 1GB), could it be related to space allocation issue?
Any ideas?
Mentor watari
Mentor
Hi @joseer
Make sure information of input.ts by the following commands.
$ ffprobe input.ts
$ ffmpeg -i input.ts
If you find color format as not NV16 (ex. NV12), change the capability from format=NV16 to format=<correct format>.
Also, I suggest you to add the following option on queue.
max-size-bytes=0
And, if you store the file by filesink on slow speed storage (like SD card, USB flash memory and USB 2.0 storage), I recommend to change it to USB 3.0 storage, too.
Hi @watari ,
Yes, the color formats are correct in NV16, I ran the next command to change them:
v4l2-ctl --device /dev/video0 --set-fmt-video=width=1280,height=1024,pixelformat=NV16
But I think you are right the issue might be bandwidth related, as I'm saving the file in a sd card, I'll check what are you suggesting and I'll get back.
HI @joseer
Do you have any update on this? Did you check if it was coming from the fact that you were using the SD card as memory?
Sorry, I had to move on with other pojects tasks and this gets a bit delayed but still need to solve it. Yes, first thing I'm planning to test a USB memory instead and see if that still happening, I'll post the result.
Jus a quick update,
