VCU not working in xilinx ubuntu (2018.3)
I'm trying to work with the VCU. I used the official BSP for zcu104 and with my own block diagram.
When I use the rootfs.tar.gz generated by petalinux, I can decode h264 file with omx_decoder, seems vcu works.
But when I'm trying to get the xilinx VCU to work on the xilinx ubuntu rootfs provided here , It fails.
With the vcu_resetn connected to an emio-gpio, the bd like this:
In petalinux, I set the "Device Driers->......->Xilinx VCU logicoreIP" Init to 'M' with petalinux-config -c kernel.
With lsmod I see that these related drivers: al5e,al5d,allegro,xlnx_vcu,xlnx_vcu_core,xlnx_vcu_clk  are loaded into the kernel.
On ubuntu I see non of these drivers are loaded. ( but the xilinx ubuntu have these modules inside )
The dmesg shows something like this
[    1.429806] xilinx-vcu-core a0140000.vcu: failed to get reset gpio for vcu.
[ 1.432454] VCU PLL: enable [ 1.432866] xilinx-vcu xilinx-vcu: xvcu_probe: Probed successfully
Seems the xilinx-vcu-core is not loaded correctly, which might caused the vcu not working.
I see that in the xilinx-ubuntu rootfs , these driver .ko files are already inside somewhere in  /lib/modules/$(uname -r)/
I don't know if this causes conflict or the linux are just using the .ko in here.
Anyway I replaced the 6 .ko files (al5e,al5d,allegro,xlnx_vcu,xlnx_vcu_core,xlnx_vcu_clk)with the one I built with petalinux, then the ubuntu stopped booting.
Any one can tell me the correct way to do this ?
Thanks !
Kang
Re: VCU not working in xilinx ubuntu (2018.3)
Hi @hu_kang ,
You might want to check all the differences between the configurations of the project from the BSP and you project. Something might be missing.
Also you might want to send the full linux log which might give more details.
Florent
Hi @hu_kang ,
Florent
With the demo hdf, I got it running. Seems something went wrong for my bd design. Thanks!
Kang
Hi @hu_kang ,
As this is now solved for you, can you kindly mark your last reply as accepted solution to close the topic?
Florent
