VCU reference clock requirement
PG252 indicates that the reference clock for the VCU should come from an external source:
However, when I run Block Automation on a VCU that I've added, it creates (by default) a reference clock from a PS-generated clock:
It does this instead of creating an external port for the reference clock, as it does for the MIG's reference clock.
I also see that the VCU TRD (which I don't have) is intended to run on the ZCU106 board--but I can't find a suitable external clock reference on that board which the VCU might use.
So I'm getting mixed signals here, and I'm uncertain of the clock requirement for the VCU's Reference Clock.
-Joe G.
Tags (3)
Re: VCU reference clock requirement
Hi @jg_bds,
As @sebo@ mentioned, theTRD can be used as a guide.
In general, the product guide takes precedence. In this case, take a look at the most recent PG252 released June 6th.
2018-07-23 09_51_05-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
Sam
Xilinx Video Design Hub
Hello @jg_bds,
This is indeed strange.
What I can tell you, is  that VCU TRD is using an external input clock (SYS_CLK):
set_property PACKAGE_PIN AH12 [get_ports SYSCLK_300_P]
set_property PACKAGE_PIN AJ12 [get_ports SYSCLK_300_N]
On the board, it is connected to a Si570 PLL. 300 MHz is it's default value.
That clock is running at 300Mhz and feed an internal PLL with 3 output clock.
The clk_out3 is the reference clock for the VCU and set to 33.333 MHZ.
Sébastien.
--Sebastien
Hi @jg_bds,
Sam
@sebo, @samk:
Thank you for the replies. I'm now planning on tapping-off an external, 300-MHz, DDR reference clock and feeding it to the VCU after a divide-by-6 trip through a BUFGCE_DIV.
@jg_bds,
I'd try to run a simple implementation on the ZCU106 first in order to validate your idea.
-Sébastien.
--Sebastien
