VCU without petalinux
I'm working with zcu106 and Vivado 2018.3. I know that is not suggested, but is there a way to use VCU for encoding/decoding without using petalinux? And a description of all its registers? H.264/H.265 Video Codec Unit v1.2 product guide describes only some registers and then speaks about only gstreamer command to do what I want to do. Thank you very much.
Re: VCU without petalinux
Hi @pierlum,
Xilinx support the VCU only with a linux OS, we do not have a baremetal driver.
All the registers for the ZynqMP, including the VCU, are documented in UG1087
Florent
Hi @pierlum,
Florent
Hi @florentw,
thanks for the reply and the support.
Pierluigi
Hi @pierlum,
If everything is clear for you, can you kindly close the topic by marking my first reply as accepted solution?
Thanks and Regards,
Florent
