VDMA 24bit AXI-Stream gives strange S2MM WSTRB
  Vivado 2017.1
  AXI_VDMA 6.3  -> AXI Smartconnect -> PS7 HP AXI
  I process the 16bit AXI-S stream to  produce a 24bit stream at the same clock.  All 24bit output are active.  But VDMA S2MM WSTRB seems to qualify only lower 8bit data out of 24bit when writing to AXI Smartconnect, as shown in second screen cap.
So the AXIS cap from ILA looks like this:
But the S2MM WSTRB is not "11111111" as expected.
I need to write all 3 bytes of 24bit.  Pls help.
Neo
Re: VDMA 24bit AXI-Stream gives strange S2MM WSTRB
Hi all,
  Found the problem.
  AXI-S TKEEP for 16bit is only 2 bit wide.  I connected it directly to AXI-S 24bit TKEEP which is 3 bit wide.
  So essentially 24bit AXI-S was getting 3'b011 input all the time.   When Smartconnect start receiving WSTRB like 8'b01001001, it cannot handle the input and did not start writing to AXI-HP at all.
  So I duplicated TKEEP[0] to TKEEP[2] to get 3'b111, and WSTRB becomes 8'b11111111 which is correct.
Neo
Hi wtneo@leica,
Do you have the ILA capture for the AXI_MM interfaces from the VDMA. From your screenshot it could be coming from the smartconnect.
Hi all,
  Found the problem.
Neo
Hi wtneo@leica,
Thank you for updating the topic.
As the issue is solved, could you kindly close the topic by marking your last reply as accepted solution (you should have an "accept as solution" button). This might help other memvbers.
Thanks and Regards,
