Visitor gordienkoa1
VDMA black collumn
Hello!
I have a problem with forwarding data on VDMA.
I write the data in DDR by jtag to the 0x01000000 buffer. Then I set VDMA to send data to the 0x05000000 buffer
Here is the frame of the data that I am recording, I also read it from the same place where it went to
And this is my shot that I read from the DDR buffer 0x05000000
This is my scheme in vivado
I focused on checking only Vdma_0 the rest of the hood is not interested in me and I do not run itvivado.png
        xil_printf("RUN MM2S \n\r");
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x00, 0x0081); //
    	Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x5C, 0x01000000); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x58, 0x0A20); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x54, 0x0A20); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x50, 0x07A0); //
        xil_printf("RUN S2MM \n\r");
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0x30, 0x0081); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0xAC, 0x05000000); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0xA8, 0x0A20); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0xA4, 0x0A20); //
        Xil_Out32 (XPAR_VDMA_8BIT_1_BASEADDR + 0xA0, 0x07A0); //
this is the initialization of VDMA in the SDK
this is a diagram of the logical analyzer, shows that the frame transfer beginswave.png
So that I do not like VDMA I did not set up I always have a black bar in this place when reading the data that dma sent.
What could be my problem?
Visitor gordienkoa1
Re: VDMA black collumn
I apologize for the disturbance. The problem seems to be not with VDMA. VDMA works like a clock. The problem in initializing the data frame buffer
        for(int i =0;i<(2592*1952/4);i++)
         Xil_Out32(0x04000000 + A, IMG_DATA[i]);
//      Xil_Out32(0x04000000 + A, 0xFFFFFFFF);
        A=A+4;
I recorded the image frame in the image.h file in the form
#define IMG_LENGTH 1264896
static u32 IMG_DATA[] = {
0x00000000,
0x00000000,
0x6f6f7071,
0x6e6e6e6e,
0x6c6c6c6c,
0x6c6c6c6c, ...
when I fill the buffer in a loop with the values ​​0xFFFFFFFF
then I see a good picture with the maximum intensity values ​​(white),
and when I read images from the IMG_DATA array, I get a black bar. Most likely the problem is in image.h
Hi @gordienkoa1,
Do you have the register dump of the VDMA? Could you make sure it does not give errors?
How do you manage the sync between read and write? Did you make sure you are not reading/writting to the same frame at the same time?
Hope that helps,
Florent
Florent
Visitor gordienkoa1
        A=A+4;
0x00000000,
0x00000000,
0x6f6f7071,
0x6e6e6e6e,
0x6c6c6c6c,
0x6c6c6c6c, ...
