VDMA in HDMI Xilinx design on board ZCU106
hi all
I a have a problem to add the VDMA block in the HDMI passthrough design.
I open the Xilinx example design.
I added VDMA between the test pattern generator to the TX HDMI 1.4/2.0 transmitter subsystem and I don't see any picture on the screen.
I checked the VDMA Input and output and also the Signals to the DDR and everything is working.
can someone help ??
Tags (2)
Re: VDMA in HDMI Xilinx design on board ZCU106
Hi assaf.regev@realityplus.io,
  • Can you help the community out and explain what you mean by working? Do you see data transferring in and out of DDR?
There are several things that could happen after inserting the VDMA. What have you done to debug the issue?
  • Is the HDMI locking to data? (locked)
  • If the HDMI is not locking to data, is there data present on the interface to the HDMI?
  • Does the VDMA list that it is transferring data?
  • How are you controlling the VDMA? Drivers or HDL?
Please include any logs or waveforms.
Xilinx Video Design Hub
