VDMA ring buffer is not in sequence
I have a design with HDMI input and output with avent's fmc board. I have configured the VDMA like this:
The VDMA configuration is:
	xil_printf("VDMA 0 Initialization\r\n");
	XAxiVdma_Reset(pdemo->paxivdma0, XAXIVDMA_WRITE);
	XAxiVdma_Reset(pdemo->paxivdma0, XAXIVDMA_READ);
//	WriteSetup(pdemo->paxivdma0, 0x10000000, 0, 1, 1, 0, 0, pdemo->hdmii_width, pdemo->hdmii_height, 2048, 2048);
//	ReadSetup(pdemo->paxivdma0, 0x10000000, 0, 1, 1, 0, 0, pdemo->hdmio_width, pdemo->hdmio_height, 2048, 2048);
	WriteSetup(pdemo->paxivdma0, INPUT_BUFFER, 0, 1, 1, 0, 0, pdemo->hdmii_width, pdemo->hdmii_height, 2048, 2048);
	ReadSetup(pdemo->paxivdma0, OUTPUT_BUFFER, 0, 1, 1, 0, 0, pdemo->hdmio_width, pdemo->hdmio_height, 2048, 2048);
	StartTransfer(pdemo->paxivdma0);
	uint32_t frame_delay = (2 << 24);
	// Master / Input / Write
	XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x30, 0x8B); // new
	XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0xAC, INPUT_BUFFER); // new
	XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0xA8, frame_delay + 1920*4); // new
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0xA4, 1920*4);
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0xA0, 1080);
    // Slave / Output / Read
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x00, 0x8B);
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x5C, OUTPUT_BUFFER);
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x58, frame_delay + 1920*4);
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x54, 1920*4);
    XAxiVdma_WriteReg(XPAR_AXI_VDMA_0_BASEADDR, 0x50, 1080);
And in the main, I have a while loop doing this:
		u32 park_ptr_reg = XAxiVdma_ReadReg(XPAR_AXI_VDMA_0_BASEADDR, XAXIVDMA_PARKPTR_OFFSET);
		u32 wr_ptr_new = (park_ptr_reg >> 24) & 0x1F;
		u32 rd_ptr_new = (park_ptr_reg >> 16) & 0x1F;
		if(wr_ptr_new != wr_ptr_old)
			u32 in_ptr  = (wr_ptr_new == 0) ? (3) : (wr_ptr_new-1);
			wr_ptr_old = wr_ptr_new;
			//input_ptr  = (u32 *)INPUT_BUFFER  + frame_size * in_ptr;
			input_ptr  = (u32 *)INPUT_BUFFER  + frame_size * wr_ptr_new;
			output_ptr = (u32 *)OUTPUT_BUFFER + frame_size * rd_ptr_new;
			Passthrough(input_ptr, output_ptr);
			printf("wr_ptr_new: %d\n", wr_ptr_new);
		if(rd_ptr_new != rd_ptr_old)
			u32 out_ptr = (rd_ptr_new == 0) ? (3) : (rd_ptr_new-1);
			rd_ptr_old = rd_ptr_new;
			//output_ptr = (u32 *)OUTPUT_BUFFER + frame_size * out_ptr;
			printf("rd_ptr_new: %d\n", rd_ptr_new);
		Passthrough(input_ptr, output_ptr);   //Copies input to output
The problem is that the rd_ptr_new is not always in consecutive order or it is decreasing rather than increasing. Also, why is rd_ptr change twice and wr_ptr changes one?. Below is a the output of the printfs:
rd_ptr_new: 0
wr_ptr_new: 0
rd_ptr_new: 1
rd_ptr_new: 0
wr_ptr_new: 1
rd_ptr_new: 2
rd_ptr_new: 0
wr_ptr_new: 2
rd_ptr_new: 2
wr_ptr_new: 0
rd_ptr_new: 0
rd_ptr_new: 2
wr_ptr_new: 1
rd_ptr_new: 1
wr_ptr_new: 2
rd_ptr_new: 2
rd_ptr_new: 1
wr_ptr_new: 0
rd_ptr_new: 0
wr_ptr_new: 1
rd_ptr_new: 1
rd_ptr_new: 0
wr_ptr_new: 2
rd_ptr_new: 1
wr_ptr_new: 0
rd_ptr_new: 0
rd_ptr_new: 2
wr_ptr_new: 1
rd_ptr_new: 0
wr_ptr_new: 2
rd_ptr_new: 2
rd_ptr_new: 0
wr_ptr_new: 0
rd_ptr_new: 2
rd_ptr_new: 1
wr_ptr_new: 1
rd_ptr_new: 2
wr_ptr_new: 2
rd_ptr_new: 1
rd_ptr_new: 0
wr_ptr_new: 0
rd_ptr_new: 1
wr_ptr_new: 1
rd_ptr_new: 0
rd_ptr_new: 1
wr_ptr_new: 2
rd_ptr_new: 0
wr_ptr_new: 0
rd_ptr_new: 2
rd_ptr_new: 0
wr_ptr_new: 1
rd_ptr_new: 2
wr_ptr_new: 2
rd_ptr_new: 1
rd_ptr_new: 2
wr_ptr_new: 0
rd_ptr_new: 1
wr_ptr_new: 1
rd_ptr_new: 2
rd_ptr_new: 1
wr_ptr_new: 2
rd_ptr_new: 0
rd_ptr_new: 1
wr_ptr_new: 0
rd_ptr_new: 0
wr_ptr_new: 1
rd_ptr_new: 1
rd_ptr_new: 0
wr_ptr_new: 2
rd_ptr_new: 2
wr_ptr_new: 0
rd_ptr_new: 0
rd_ptr_new: 2
wr_ptr_new: 1
rd_ptr_new: 1
wr_ptr_new: 2
rd_ptr_new: 2
rd_ptr_new: 1
Thanks for the help.
Re: VDMA ring buffer is not in sequence
Hi @aripod,
I will depends on what are the states of each action (read or write).
  • You will not read into a fame buffer you are writing into. So if you are writing in the next buffer, the rd buffer will stay in the same buffer (it will revert back)
  • Each time you finish reading a frame the read pointer will be incremented. But if it is not the latest frame available, you will revert back to the previous one
Florent
Hi @florentw,
What would make the read buffer not being available? That I am reading from it slow?
Hi @aripod,
If you are writing to a frame buffer or if the buffer is not the latest one, then you should not read in the frame buffer so "it will not be available for reading".
It might be that reading is too slow or too rapid
Florent
Hi @florentw,
Do I need to configure something else or what I've shown is enough?
HI @aripod,
Yes it seems correct
Florent
Hi @aripod,
Do you have any updates on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
It does not seem to be correct as the issue still remains and I don't know how to debug this properly as the registers seem to be set how they should.
Hi @aripod,
What is the issue? You only described the pointer values, I do not think there is an issue with them.
Do you see any error on the output?
Florent
Hi @florentw,
There is an issue with the input. As the pointers do not go in order, you see the output image with a strange effect because it does not show frames consecutively. Therefore, you see an old frame after the what would be current one. I believe the reason is the pointers not being sequentially. To test it quickly, I changed from 3 to 2 so the next frame to show will be the other one that it is not currently used and then the output image looks smoother.
Shouldn't the pointers be consecutive so in some sort, the "follow" each other?
HI @aripod,
For me it will really depends on how the frames are ready for writing reading.
I recommend you to use an example design using the VDMA as the xapp1285 and see what behaviour in it.
Florent
