VDMA's SDK code
I tried the project below (see the attached design), i succeded it withut the vdma, but when i added the VDMA i didn't know what to write on the SDK code to program this VDMA.
Tags (2)
Re: VDMA's SDK code
You can find a lot reference design on xilinx.com, which contains SDK codes : xapp742, xapp1218, xapp1205,xapp794,xapp890,xapp1167,xapp1250,xapp1218
Re: VDMA's SDK code
Hi @xud,
Which project is working on Vivado 2015.4 please ?, because I'm using this version
Re: VDMA's SDK code
xapp1285 is working on v2015.4, it contains VDMA as well
Re: VDMA's SDK code
ok Thanks
Re: VDMA's SDK code
Hi @mkooli,
If you have all the information you need, please close the thread by marking one of the responses as good answer.
Xu
Re: VDMA's SDK code
Sorry, I still have the same problem, no VDMA configuration found for my design, still searching...
Re: VDMA's SDK code
@mkooli did you find a proper guide or tutorial to configure VDMA using SDK (C code)? I am facing the same problem!
Re: VDMA's SDK code
Hi @mkooli,
xapp1285 contains the HW + SW design. What more do you need?
Florent
Florent
Re: VDMA's SDK code
As a beginner I faced the same problem in getting the VDMA to work. So I would like to share my experience of a workaround to get something started, hoping this might help other beginners as well. What I did was getting the VDMA to work as a triple buffering VDMA. A well guided C code was located in the VDMA example in SDK [Xilinx\SDK\{version}\data\embeddedsw\XilinxProcessorIPLib\drivers\axivdma_v6_1\examples]. vdma.c contains all the information, but still as an absolute beginner still I found this a bit too much of information. So what I did was without thinking how this code actually works I just tried to get the VDMA based on this code. The easiest way was to make the other c file vdma_api.c a header file (saved the c file as vdma_api.h). Then I included it in my c code and just called the run_triple_frame_buffer() method. I know this is not much but it is enough to get VDMA running at least.
Hope this might help other beginners as well. :-)
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xparameters.h"
#include "xaxivdma.h"
#include "vdma_api.h"
#include "xil_types.h"
#include "xil_io.h"
XAxiVdma 								AxiVdma;
int main()
    init_platform();
    int status;
	//Checking and configuring VDMA
	status = run_triple_frame_buffer(&AxiVdma, 0, 1920, 1080, XPAR_PS7_DDR_0_S_AXI_BASEADDR + 0x1000000, 100,0);
	if (status != XST_SUCCESS) {
		xil_printf("VDMA Transfer of frames failed with error = %d\r\n",status);
		return XST_FAILURE;
	} else {
		xil_printf("VDMA Transfer of frames started \r\n");
    cleanup_platform();
    while (1) {
    return 0;
