VDMA - single AXI4 interface performance difference?
I noticed an option under the Advanced tab to "Enable Single AXI4 Data Interface". that creates a single M_AXI interface instead of a separate MM2S and S2MM interface when using both a write and read channel.
I assume this is to reduce resource usage, but is there any performance difference when using this combined interface, compared to separate MM2S and S2MM interfaces?
Update: I tried enabling single AXI interface on two VDMAs in a nearly full Artix 100, and I got all kinds of errors saying the resource utilization was exceeded.  It fits with room to spare using the separate interfaces on both VDMAs, so I guess my assumption that the single interface saves resources was incorrect.  If so, what is it used for?  The VDMA user's guide does not mention this option.
Re: VDMA - single AXI4 interface performance difference?
Hi @reaiken,
Hovering over the option shows:
It looks like this was added to make interfacing to the core easier and not necessarily for saving on resources.
Sam
Xilinx Video Design Hub
Hi @reaiken,
Sam
HI @reaiken,
Is everything clear for you on this topic?
Thanks and Regards,
