VDMA - single AXI4 interface performance difference?
I noticed an option under the Advanced tab to "Enable Single AXI4 Data Interface". that creates a single M_AXI interface instead of a separate MM2S and S2MM interface when using both a write and read channel.
I assume this is to reduce resource usage, but is there any performance difference when using this combined interface, compared to separate MM2S and S2MM interfaces?
Update: I tried enabling single AXI interface on two VDMAs in a nearly full Artix 100, and I got all kinds of errors saying the resource utilization was exceeded.  It fits with room to spare using the separate interfaces on both VDMAs, so I guess my assumption that the single interface saves resources was incorrect.  If so, what is it used for?  The VDMA user's guide does not mention this option.
Tags (2)
Re: VDMA - single AXI4 interface performance difference?
Hi @reaiken,
Hovering over the option shows:
It looks like this was added to make interfacing to the core easier and not necessarily for saving on resources.
Sam
Xilinx Video Design Hub
Hi @reaiken,
Sam
HI @reaiken,
Is everything clear for you on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
