VDMA writing frames problem
i downloaded this tutorial :       "Adam Taylor’s MicroZed Chronicles, Part 119: VDMA software"
 and tryed to test it , i fllowed exactly what is mentionned in the tuto but it doesn't  work, the problem  is that the VDMA doesn't write the fames in the memory,
How can i resolve this problem please, is there something to verify.
Tags (2)
Re: VDMA writing frames problem
Hi @mkooli,
-> what did you use to monitor that? How do you know that it is not writting in the memory? Do you have an error message in the UART console?
Florent
Florent
as it 'showed in the screen shot ; transfer of frames failed    also i tried to see the output of the test pattern generator  "m_axis_video"
using the chipscope, i have a video stream  but when i see the output of the VDMA    "M_AXIS_MM2S"  i have no thing (0000) ,  this is the problem
Visitor mohamed34
Hi there,
Someone resolved the probleme with this tutorial?
