Observer kulich
VPSS - Full Fledged deinterlace driver problem
I found problem in VPSS driver. In configuration:
Input((768x288-Interlaced)Deintrelacer ->((768x576)Scaler -> Output(800x600).
Video stream after Deinterlacing have doubled lines count (288 lines to 576) and this stream is going to scaler. But is not possible set scaler Zoom windows to this size. Problem is in function static XVprocSs_ScaleMode GetScalingMode(XVprocSs *XVprocSsPtr) when function test validateWindowSize validity. This problem code:
  if(XVprocSs_IsZoomModeOn(XVprocSsPtr))
    /* Read PIP window setting - set elsewhere */
    XVprocSs_GetZoomPipWindow(XVprocSsPtr, XVPROCSS_ZOOM_WIN, &win);
    /* validate window */
    status = validateWindowSize(&win,
	                            StrmInPtr->Timing.HActive,
	                            StrmInPtr->Timing.VActive);
    if(status != XST_SUCCESS)
      XVprocSs_LogWrite(XVprocSsPtr, XVPROCSS_EVT_CFG_MAX, XVPROCSS_EDAT_MAX_RDWINBAD);
	  return(XVPROCSS_SCALE_NOT_SUPPORTED);
    else
      XVprocSs_LogWrite(XVprocSsPtr, XVPROCSS_EVT_CFG_MAX, XVPROCSS_EDAT_MAX_SCALEUP);
      return (XVPROCSS_SCALE_UP);
I changed to this:
    // TODO - Report
    u16 VActive;
    if( XVprocSs_GetSubsystemTopology(XVprocSsPtr) == XVPROCSS_TOPOLOGY_FULL_FLEDGED ){
    	if( StrmInPtr->IsInterlaced )
    		VActive = 2*StrmInPtr->Timing.VActive;
    	else
    		VActive = StrmInPtr->Timing.VActive;
    } else {
    else
This is working correctly
Kulich
Observer kulich
Re: VPSS - Full Fledged deinterlace driver problem
Little correction. In previous post is a mistake (missing calling function validateWindowSize). This is better and working (tested) code:
// TODO - Report
    u16 VActive;
    	else
    } else {
VActive);
HI @kulich
yes you are right valid window size check of interlaced video seems incorrect. I will check on this. and report this to development if need be, and get back to you.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
