VPSS Problem
My Image Processing pipeline is
VintoAXI -> Demosaic -> Gamma LUT -> VPSS (CSC configuration only ) -> Image enhancement -> VPSS(Full Fledged)  -> AXItoVout
   Here my design is working fine. but i want to configure Brightness, Contrast and Saturation of the VPSS(CSC only) at run time.Here the problem is the Image enhancement IP will support only YCbCr format.So i used VPSS(CSC mode only) to convert RGB to YUV444. At the same time VPSS(Full Fledged Mode) which is used for Color conversion (YCbCr to RGB) and Scaling the Image. So i don't known how to modify the code.
kannan
Re: VPSS Problem
Hi ,
            Finally i found the functions for Brightness , contrast , Saturation , Rgain , Bgain and Ggain in xvprocss. Now i am able to control these functionality at run time.
kannan
Re: VPSS Problem
Hi @kannan,
Can you clarify your question for the community?
"Here my design is working fine" - Which design/pipeline are you referencing? Can you confirm at which point the design is working fine?
"So I don't know how to modify the code" - How are you trying to modify the code? What issue are you running into?
Sam
Sam
Xilinx Video Design Hub
Re: VPSS Problem
Hi ,
kannan
