VPSS - scaler only mode in 4ppc
My input video stream  is in 4 pixels per clock. I need to use the VPSS to upscale it.
But, it seems the linux driver does only support 1 and 2 ppc mode while the HW can configure the scaler up to 4 ppc.
Is there a plan to update the linux driver? Or, is there a way to configure it (outside the driver) to enable the 4PPC?
If I need to downgrade to 2 PPC, how would you do it?
--Sebastien
Re: VPSS - scaler only mode in 4ppc
Hi @florentw ,
Thanks for the follow up. We're able to backport the scaler driver from git (current head version) to 2018.3 currently used on our project.
It solved the issue and the video chain in the PL part can stay full 4PPC.
--Sebastien
Hi @sebo
[Florent]  - Yes, I believe this should be in 2019.2
It seems to be already available on the master branch on github:
https://github.com/Xilinx/linux-xlnx/commit/2f547b734cdf2af308820663495c48861bfb489c
[Florent]  - You could check the AXI4-Lite transactions required to configure the subsystems and then use the devmem in the linux user space. Or port the baremetal driver. But then you cannot use the V4l2 framework (and thus GStreamer).
[Florent] - To change the PPC, you could use the AXI4-Stream Data Width converter IP as shown in my Video Series 12. However I am not sure how this integrates in the V4L2 framework.
Florent
@florentw
Thanks. I'll have a look at the video series. We'll go for the driver backport for now.
As baremetal programming is concerned, the vpss documentation does not give the memory map and register details. Where is this information?
--Sebastien
HI @sebo
[Florent] - The register space is given in the latest version of the PG231 (May 22, 2019). Howerver this is only for debugging purposes. Xilinx does not support direct access to the registers.
In baremetal users should use the drivers
Florent
Your video series #12 (Different ppc configuration between interfaces) does not talk about the AXI stream FIFO does it?
Is such ip is to be used if the stream cannot be halted. That's what I'm trying to use to handle the scaler in 2PPC while my stream is in 4PPC (input)
--Sebastien
Hi @sebo
In the Video series 13 I am using a AXI4-Stream data FIFO.
I am not sure why you are seeing that the stream cannot be halted. Maybe you need to make sure you reset (empty) the FIFO when the stream is halted to make sure the pipe is cleared
Florent
Hi @sebo
Did you get all the answers you needed from me on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Hi @florentw ,
--Sebastien
