VTG + FFMPEG
I'm implementing a simple video pipeline (TPG + VDMA) on Zynq.
I can see under linux /dev/video0 and /dev/media0 nodes.
I want to capture and display the video framebuffer. I'm using FFMPEG for this purpose.
When I run ffmpeg -i /dev/video0, I have this error:
[video4linux2,v4l2 @ 0x55890] Not a video capture device.
/dev/video0: No such device
Any suggestion?
Mentor
Mentor
Re: VTG + FFMPEG
Hi @tgharbi2020
Would you make sure capability on /dev/video0 by the following command ?
v4l2-ctl -d /dev/video0 --info
Best regards,
Re: VTG + FFMPEG
 Hi @watati
This is the output of the command: v4l2-ctl -d /dev/video0 --info
Driver Info (not using libv4l2):
Driver name : xilinx-vipp
Card type : video_cap output 0
Bus info : platform:video_cap:0
Driver version: 4.14.0
Capabilities : 0x84201000
Video Capture Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04201000
Streaming
Extended Pix Format
Re: VTG + FFMPEG
Any other suggestion please?
Re: VTG + FFMPEG
Hi guys,
Is there any other suggestion/explanation?
I have the same output error ("not a video capture device") when using yavta.
Mentor
Mentor
Re: VTG + FFMPEG
Hi @tgharbi2020
Whould you share BD, if possible ?
It's hard to explain it without block diagram.
Best regards,
Re: VTG + FFMPEG
Hi @watari
and for detailed vue:
Mentor
Mentor
Re: VTG + FFMPEG
Hi @tgharbi2020
Whare do "vid_io_in" signals on vid_in_axis4 come from ?
What kind of signals are "vid_io_in" on vid_in_axis4 ?
I guess you need to add more something in dts or modify your design...
Also, refer the following URL.
Especially, you set proper value on each properties, after finding /dev/video*.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841767/Xilinx+V4L2+driver
Best regards,
Re: VTG + FFMPEG
vio_io_in comes from a custom video decoder in FPGA, representing active video + sync signals.
I join here video dts section:
	amba_pl {
		#address-cells = <0x1>;
		#size-cells = <0x1>;
		compatible = "simple-bus";
		ranges;
		vdma: dma@43000000 {
			#dma-cells = <0x1>;
			clock-names = "s_axi_lite_aclk", "m_axi_s2mm_aclk", "s_axis_s2mm_aclk";
			clocks = <0x1 0xf 0x1 0xf 0x1 0xf>;
			compatible = "xlnx,axi-vdma-6.3", "xlnx,axi-vdma-1.00.a";
			interrupt-names = "s2mm_introut";
			interrupt-parent = <0x4>;
			interrupts = <0x0 0x3b 0x4>;
			reg = <0x43000000 0x10000>;
			xlnx,addrwidth = <0x20>;
			xlnx,flush-fsync = <0x1>;
			xlnx,num-fstores = <0x1>;
			dma-channel@43000030 {
				compatible = "xlnx,axi-vdma-s2mm-channel";
				xlnx,datawidth = <0x18>;
				xlnx,device-id = <0x0>;
				xlnx,genlock-mode;
				xlnx,include-dre;
		v_tpg@43c10000 {
			clock-names = "ap_clk";
			clocks = <0x1 0xf>;
			compatible = "xlnx,v-tpg-8.0", "xlnx,v-tpg-5.0";
			reg = <0x43c10000 0x10000>;
			xlnx,s-axi-ctrl-addr-width = <0x8>;
			xlnx,s-axi-ctrl-data-width = <0x20>;
			reset-gpios = <&gpio 54 1>;
			xlnx,max-height = <720>;
			xlnx,max-width	= <576>;
			tpg_ports: ports {
				#address-cells = <1>;
				#size-cells = <0>;
				tpg_port0: port@0 {
					/* Fill the field xlnx,video-format based on user requirement */
					reg = <0>;
					xlnx,video-format = <0>;
					xlnx,video-width = <8>;
					tpg_out: endpoint {
						remote-endpoint = <&vcap0_in0>;
		video_cap {
		    compatible = "xlnx,video";
		    dmas = <&vdma 0>;
		    dma-names = "port0";
		    ports {
			#size-cells = <0>;
			port@0 {
			    reg = <0>;
			    direction = "input";
			    vcap0_in0: endpoint {
				remote-endpoint = <&tpg_out>;
Re: VTG + FFMPEG
HI @tgharbi2020
Are you sure /dev/video0 represents the TPG?
Did you try enabling libv4l2?
Florent
Re: VTG + FFMPEG
Hi @florentw
yes, video0 is the vcap of my pipeline: TPG + VDMA
I don't have any other internal/external video source.
I'm not sure about libv4l2 but I still have the same error even with yavta
I attach some log output
Re: VTG + FFMPEG
HI @tgharbi2020
What vivado + petalinux versions are you using?
Make sure you are using the latest one.
I believe in some earlier versions, the TPG had to be used as a path-through device, this might be why the driver was not exposing it as a capture device.
Florent
Re: VTG + FFMPEG
Hi @florentw
I'm using vivado + petalinux 2018.3
I resolved the error by adding in bootargs: xilinx-video.is_mplane=0.
But, the capture is still not working, with another error:
ffmpeg -f v4l2 -list_formats all -i /dev/video0
... [video4linux2,v4l2 @ 0x6bff0] ioctl(VIDIOC_G_INPUT): Inappropriate ioctl for device /dev/video0: Inappropriate ioctl for device
I have doubts about xilinx-video driver of xilinx linux 4.14.
So, I built the last xlnx kernel 5.4, but zynq boot hangs after pipeline registration:
https://forums.xilinx.com/t5/Video/xilinx-video-Zynq-boot-hangs-after-video-cap-pipeline/m-p/1085474
Finally, I tried to not use V4L2 framework. So, I tried to read framebuffer from DDR and stream it to a pipe, as an input for ffmpeg (ffmpeg -i pipe:0 ...). For this purpose, I need to define a callback function of video frame buffer write (linux app). Thus, my questions here: https://forums.xilinx.com/t5/Video/Video-Framebuffer-Write-handling-interrupt-in-linux-app/m-p/1085151#M31311
Help is welcome
