VTPG [Synth 8-439] Module not found
Hi, I am using VIvado 2018.1 implementing a design using a couple of V_TPGs in a block design for a xc7k325tffg676-1 device.   When I generate output products the VTPG fails synth every time even after moving the project to a very short path name folder.   Is there a known solution for this error?
Tim
Re: VTPG [Synth 8-439] Module not found
@florentw,
   Sorry, I resolved it.   I closed Vivado, relaunched Vivado and opened the project, reset output products and tried regenerating output products and this time it synthesized successfully.
   Strange, but resolved.
Tim
HI @tim_severance,
Could you share you log file?
Could you check in the folder .runs/synth_1 if there is one folder for the failing VTPG? If yes could you share the vivado_hls.log file if any?
Florent
@florentw,
Tim
