VTpg Random noise pattern halt?
   I am working with the HDMI source example design running on a KC705 in Vivado 2017.4.   An engineer I am working with is requesting that I take the pattern that outputs random snow and stop it somehow so the existing random pixels stay static on the screen until I tell the snow to start changing again.
   Does anybody know if this is possible to do with the v_tpg?
Tim
Re: VTpg Random noise pattern halt?
@tim_severance
You can't do that with the TPG IP, because it does not store a full frame of the pattern image (that would take lots of memory!).  It calculates the image on the fly, on a pixel-by-pixel basis, and outputs the data.
The easiest way to do what you want is to put the TPG in front of a VDMA IN to a frame memory, then display the frame contents with a VDMA OUT.   Turn the VDMA IN off via the AXI4-Lite interface with a MicroBlaze write and the output VDMA image will freeze. Turn the VDMA IN back on and it will go live again.    The VDMA OUT will keep a constant stream of output data going, frozen or not.
@tim_severance
Scholar watari
Hi @tim_severance
I guess your co-worker request to output PRBS7 pattern to measure waveform and clock jitter on HDMI by oscilloscope.
If yes, as far as I know,  v_tpg does not support it. But it it easy to implement this function by RTL.
Best regards,
Thanks @watari and @reaiken,
   I like the VDMA idea.   I was just hoping for a quick solution using the existing desing.
Tim
