Video Beginner Series 11: From Sensor output to RGB image
Introduction
This Video Beginner Series 11 explains how an output from a sensor is converted to a RGB image
Summary
1. Introduction Color Image sensors
2. Tutorial - Using the Sensor Demosaic IP
3. What next?
Florent
Video Beginner Series 11 - Introduction Color Image sensors
Introduction to image sensors
An image sensor is an electronic device that receive light to electric signals. There are two main types of image sensors: Charged-Coupled Devices (CCD) sensors and Complementary Metal-Oxide Semiconductor (CMOS) sensor.
A sensor is an array of pixels. A pixel can be compared to well which collects photons (light information) for a certain amount of time called exposure time.
At the end of the exposure time, the more photon each pixel gets the higher will be the output value for this pixel.
Color image sensor
To add color information, the sensor uses a Color Filter Array (CFA). On each pixel a filter with a specific color is applied. There are different CFA filters used as the Bayer filter (most commonly used), the RGBE filer, the CYYM filter or the CYYM filter.
Thus, each pixel will only receive photons corresponding to one specific color
At the sensor output, for each pixel, you get a single value for this specific color. In a RGB image, each pixel has three values, one for each component (one value for Red, one value for Blue and one value for Blue). To create a RGB image from the sensor output, the missing value needs to be computed. This computation is called demosaicing (or sometimes deBayerization because of the Bayer filter).
Demosaicing with Xilinx devices
For the demosaicing images captured with a Bayer image sensor with Xilinx devices, users can use the Sensor demosaicing IP (PG286).
Florent
Video Beginner Series 11 - Tutorial - Using the Sensor Demosaic IP
Note 1: This tutorial is intended to be used only with Vivado 2018.1 and only in simulation
Note 2: A valid license for the Test Pattern Generator is required to build the design.
Analyzing Bayer images
  1. Download the tutorial files and unzip the folder
  2. Open the image file XVES0011/img/bayer_img_1.png. This image represents what an output from a color sensor can look like (only one value per pixel (one color), the others are set to 0). If we zoom in, we can clearly see the Bayer CFA. We can note that the first pixel (top left corner) is a red pixel
  1. Open the image file XVES0011/img/sensor_img_1.pgm with GIMP. This is the same image as bayer_img_1.png but with only one component per pixel. This is the image we will use for our simulation.
Build the Vivado project
  1. Open Vivado 2018.1
  2. In the tcl console, cd into the unzipped directory (cd <path>/XVES_0011)
  3. In the tcl console, source the script tcl (source ./create_proj.tcl)
  4. add the image file sensor_img_1.pgm to the simulation sources (Add sources > Add or create simulation sources > Add files > File of types: All Files)
Analyze the design
  1. Open the Block Design
  2. We can see that the design gets Video data as input (Bayer data) and output video data (RGB data) converted by a Sensor Demosaic IP
  3. The Sensor Demosaic IP needs to be configured and started. The configuration set the fame size and the Bayer Phase (refer to for PG286 detail on the configuration). In this simulation, the Sensor Demosaic IP is configured by an AXI VIP IP. The Bayer phase specify the starting position of the Bayer filter on the sensor. There are 4 different configurations. In our case we are in the configuration 0.
Run the simulation
  1. Lunch the behavioral simulation and run it for 50ms.
  2. On the waveform, we can see that the input data width is 8 bits (1 component per pixel) while the output data width is 24 bits (3 components per pixel)
  1. When the simulation is finished, open the output image file XVES_0011/proj_1/proj_1.sim/sim_1/behave/xsim/demosaic_RGB.ppm with GIMP. We can see that we have now a RGB image
15. Close the simulation and the project
Florent
Video Beginner Series 11 - What Next?
What Next?
  • You liked this Video Series?
    • Make sure you are following the Xilinx Video Series topic to be informed when an new topic is published (Go to the Xilinx Video Series topic > Options > Subscribe)
Florent
