Video On-Screen Display (OSD) no box no text appears help!
Hello I'm developing a project using Video on screen display 6.0 as OSD. I know that is deprecated but it is free. I use VDMA+Video on screen display. On layer 0 I have graphic controller and on layer 1 I have external axis video from VDMA. Video on layer 1 pass on output but on layer 0 text or boxes not appear. Looking at status register I have not error. Thank you.
This is the code I use in microblaze to program OSD to write a BOX using suggested API. To program OSD I referred to Video on screen display 5.01a UG that is very detailed.
u32 clut[16]={
0x00000000,
0xffffffc0,
0x0000ffc0,
0x80808080,
0x00ff00c0,
0x00000000,
0x00ffffc0,
0x00000000,
0xff0000c0,
0x00000000,
0xff00ffc0,
0xffffffa0,
0xffff00c0,
0x00000000,
0x000000c0,
0x00000000};
u32 Instruction[8];
XOsd_SetActiveBank(&Osd, 0, 0,0,0,0);
XOsd_SetActiveSize(&Osd, 720, /*576*/625);
XOsd_SetBackgroundColor(&Osd, 0x00FF, 0x0000, 0x0000); //ptr OSD //R //B //G
XOsd_SetLayerDimension(&Osd, 0, 0, 0, 720, 576);
XOsd_SetLayerDimension(&Osd, 1, 0, 0, 720, 576);
XOsd_SetLayerAlpha(&Osd, 0,0, 0xFF);
XOsd_SetLayerAlpha(&Osd, 1,1, 0xFF);
XOsd_SetLayerPriority(&Osd, 0, 1);
XOsd_SetLayerPriority(&Osd, 1, 0);
XOsd_EnableLayer(&Osd, 0);
XOsd_EnableLayer(&Osd, 1);
XOsd_LoadColorLUTBank(&Osd, 0, 0, &clut[0]);
XOsd_LoadCharacterSetBank(&Osd, 0, 0, &fontchar[0]);
XOsd_LoadTextBank(&Osd, 0, 0, (u32 *)TextData);
XOsd_CreateInstruction(&Osd, &Instruction[0], 0, XOSD_INS_OPCODE_BOX, 0, 0, 0, 400, 400, 0, 10);
XOsd_CreateInstruction(&Osd, &Instruction[4], 0, XOSD_INS_OPCODE_END, 0, 0, 0, 0, 0, 0, 0);
XOsd_LoadInstructionList(&Osd, 0, 0, Instruction, 2);
XOsd_SetActiveBank(&Osd, 0, 1,1,1,1);
Thank you.
Re: Video On-Screen Display (OSD) no box no text appears help!
So I solved the problem and OSD IP is working properly. The video on screen display (OSD) IP 6.0 have hardware and software bugs:
1) The XOsd functions to initialize OSD work correctly and you can use this sequence to initialize OSD (in this example layer 0 GC and layer 1 axis video)
XOsd_RegUpdateEnable(&Osd);
XOsd_Enable(&Osd);
XOsd_SetActiveSize(&Osd, 720, 625);
XOsd_SetBackgroundColor(&Osd, 0x0080, 0x0080, 0x0080); //ptr OSD //R //B //G
XOsd_SetLayerAlpha(&Osd, 0,0, 0x100);
XOsd_SetLayerAlpha(&Osd, 1,1, 0x100);
The others XOsd_* API to configurate GC doesn't work. Write your own functions following UG OSD IP 5.01a
https://www.xilinx.com/support/documentation/ip_documentation/v_osd/v5_01_a/pg010_v_osd.pdf
Note the link of PG010 is for v5.01a, which provides a lot more details ,compared to 6.0, in Appendix D
showing the examples on how to program graphics controller (Font Ram and Text RAM). Please double check if your instruction list matches the ones shown in the examples.
2) There is an hardware bug on OSD IP. The OSD has distorsion on text if the upstream device deasserts the tready signal mid-line. In my case I have Video direct memory access as upstream device. My lines are 1440 bytes. And as default buffer line depth of VDMA is 512 byte. I selected 4096 byte and now work correctly. I also added two AXI4-stream data fifo one on axi streaming input of OSD IP and one on axi streaming ouput of OSD IP. As explained here in the solution https://forums.xilinx.com/t5/Video/Video-On-Screen-Display-OSD-IP-shift-text-to-left-when/td-p/849466 OSD IP need fifo to avoid distorsion.
Adding this 2 line code now boxes appear.
XOsd_Enable(&Osd);
So now boxes appear but text doesn't appear. Could anyone help me? Thanks.
Hi @pierlum,
Did you enable both box and text in the configuration GUI in vivado?
I have enabled both instruction. I correctly loaded font and text but box appear and text not. Do you know if there is an working example design that uses version 6.0 of the IP? Thanks for the help!
Hi @pierlum,
I think you can use xapp1205 but it is using vivado 2013.4
Hi @
Hi @pierlum,
I do not think there is a more recent example design with the OSD. Again, everything was moved to the Video Mixer and it is the recommendation
Thaks for the help. Video Mixer can mix up to 8 layer but has no OSD. Is there or is in developing a new OSD IP?
HI @pierlum,
I think you can use the logo box in the video mixer
Thanks for the help! I have to see if video mixer support loading of the font and than I print string or if I have to manually draw characters.
Hi @pierlum,
I think you can now display the text plus box. Could you kindly reply with your solution and mark it as accepted solution to close the topic?
XOsd_Enable(&Osd);
