Observer tmiller
Video PHY reference clock
I am currently trying to add two DisplayPort transmitters to an existing FPGA design (xcku040-ffva1156). The transmitters will each use the DP TX subsystem (v2.0) and the Video PHY controller (v2.0). Both transmitters will sit in the same bank, with a line rate of 2.7 Gbps and identical video timings. The bank is currently provided with a single 156.25MHz external reference clock. I have two questions:
1) Is 156.25 MHz an acceptable frequency? I have used the DisplayPort IP v7.0 before, and the documentation specifies that a 270 MHz reference clock is required for all line rates. I'm not so familiar with the Video PHY, but I suspect the same applies. I can't see any information in the documentation.
2) Can two Video PHYs within the same bank share the same reference clock?
https://japan.xilinx.com/support/documentation/ip_documentation/displayport/v7_0/pg064-displayport.pdf
https://www.xilinx.com/support/documentation/ip_documentation/vid_phy_controller/v2_0/pg230-vid-phy-controller.pdf
https://www.xilinx.com/support/documentation/ip_documentation/dp_tx_subsystem/v2_0/pg199-displayport-tx-subsystem.pdf
Thank you for any help.
Re: Video PHY reference clock
HI @tmiller,
-> I am quite sure the same rules apply (the DP subsystem includes the DP IP), so I think you need to use 270. I will ask for more clarification in the new documentation
-> I would say yes if they in adjacent QUADs and if they don't to support different resolutions
Florent
Florent
HI @tmiller,
Florent
Florent
