Observer bkochavi
Video Processing Subsystem deasserts TREADY
I am using a VPSS to scale down a 1920x1080@30 FPS video stream and doing color space conversion from RGB to YUV422.
This all works fine but when I disable the scaling functionality by setting the input image size equal to the output image size the VPSS deasserts TREADY after around 20% of the picture have passed through the core. I can see the downstream pipeline is still ready for data so this does not happen due to backpressure.
Because I need low latency processing I am not using a VDMA in the video pipeline so when the situation I described above happens the pressure on the pipeline is getting too high and i am loosing data.
Putting a big FIFO in the pipeline helps but does not solve the issue.
The Video Pipeline is clocked at 150 MHz.
Is there anything I need to do when disabling the scaling functionality and just using the color space conversion?
Thanks in advance!
Ben
Observer bkochavi
Re: Video Processing Subsystem deasserts TREADY
Hi @florentw , thank you for your response. I am sorry for the delay.
Please note that when I initialize the VPSS from reset to output 1920x1080@30 FPS the problem also occurs.
I found out that increasing the maximum number of lines and pixels solved the issue. I found the solution in this thread https://forums.xilinx.com/t5/Video/Debugging-Scaler-Only-Video-Processing-Subsystem/m-p/804460.
Thank you!
HI @bkochavi
Any time you are changing the configuration of the VPSS you need to apply a reset on it.
Could you check if you got the same behaviour if you reset the core?
Observer bkochavi
Thank you!
