Newbie ggrummer
Video Processing Subsystem - interlace Size Registers Have No Effect
We can't change the VPSS Deinterlacer horizontal and vertical image size.  In debug mode we can write the horizontal and vertical size registers, read them to see that they’ve changed, but the Deinterlacer does not change.  Once we supply the new image, the Deinterlacer stops working.
The only time the images size values can be entered is after a power on reset.  A normal reset has no effect.
How does one get the Deinterlacer to accept a new image size?
Re: Video Processing Subsystem - interlace Size Registers Have No Effect
You can look at the example codes given in the driver folder to see how these parameters are set - . Alternately check the XAPP1291 which has the deinterlacer setup support too - http://www.xilinx.com/support/documentation/application_notes/xapp1291-video-subsystem.pdf
Anirudh
I assume that it doesn't work if you use the actual top-level function calls to the VPSS? You're really not supposed to go hit individual registers without using the driver.
www.xilinx.com
Anirudh
Please take a look at main.c under C:\Xilinx\SDK\2017.1\data\embeddedsw\XilinxProcessorIPLib\drivers\vprocss_v2_3\examples\src
Search for following lines, change the thisCase->width_in and thisCase->height_in should allow you to use a different size image.
if (VpssPtr->DeintPtr != NULL) {
// Video In: 480i YUV Video Out: 1080P RGB
thisCase->width_in = 720;
thisCase->height_in = 240;
