Visitor esbfut_2
Video Processing Subsystem : register map
I'm trying to run "Video Processing Subsystem" v2.0 in QNX OS.
Does anyone have a register map of "Video Processing Subsystem"?
Kind Regards,
Uchida @ FUJI SOFT INC.
Re: Video Processing Subsystem : register map
Hi @esbfut_2,
The VPSS register map is hidden to the user. You need to use the API to access each different function.
Direct access to the registers are not supported (and you may have issues).
Florent
Florent
Hi @esbfut_2,
Florent
Florent
