Observer sundar19
Video Series 21: TPG Application on ZC702 in petalinux
respected sir,
I have got the TPG output on my zc702 bare metal. Now i want to build OS using petalinux for the same. pls do guide me how to do the same. I have the hdf in hand (PL part) but what about my C files in SDK (PS part).
Thanks in advance.
Re: Video Series 21: TPG Application on ZC702 in petalinux
Hi @sundar19
You should be able to build a petalinux image from the HDF file. If you do direct configuration of the register through the linux user space, it should be pretty straight forward. If you want to use the drivers, there will be more work needed as you will need to use the ADV7511 driver. This is not something I have do thus I cannot guide you further.
Florent
Observer sundar19
Thank you very much @florentw sure to make it with the your support!
