Video Test Pattern Generator blocked in Vivado 2017.4
I'm trying to use the IP Video Test Pattern Generator in Vivado 2017.4, but when I try to validate a design with it I get the following error:
How can I fix it? Looks like there is something to do with the licenses, but I found a lot of tutorials using this IP, although in Vivado 2018, and didn't expected I needed some license to use it.
Re: Video Test Pattern Generator blocked in Vivado 2017.4
Hello @tiago0297,
The reason why you are seeing this issue is because you have generate your license for the DISK_SERIAL_NUM=a6bf4afb
Whereas the actual DISK_SERIAL_NUM on this particular machine is 5e45a2ca (i.e. C: Drive Serial Number    | DISK_SERIAL_NUM=5e45a2ca)
Therefore, please regenerate all your node-locked licenses targeting either one of 4 of your Network Interface Card IDs or a valid  DISK_SERIAL_NUM=5e45a2ca.
This will solve your issue then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @tiago0297,
The first step is to do as the message states.
"Please run report_ip_status for more details and recommendations" And then post your results.
Report IP Status is found under the Reports tab, or you can use the tcl console.
-Sam
Xilinx Video Design Hub
Hi @tiago0297,
When I write a tutorial for the Video Test pattern Generator as my Video Series 4 for example, I always include the following note:
Note: A valid license for the Test Pattern Generator is required to build the design.
Yes a license is required for the TPG IP for any vivado version prior to 2018.3. However, it is a free license. You can generate it from your account.
If you had done a search on the forums, you would have found the following topic posted few weeks ago:
https://forums.xilinx.com/t5/Video/TPG-license-not-found/td-p/923260
It contains the steps to generate the TPG license.
Then once it is generate, you can follow the steps mentioned by @samk.
Hi, thanks for the answer
I got the license for the Test Pattern Generator. Also, I already loaded it in my Vivado. Here is my Manage License > View License Status screen:license.PNG
 Unfortunatelly, the error persisted. When I run report_ip_status, this is the result
Did I do something wrong? To add the lincese, I followed what @florentw said, got the file sent in my email, gone to Help > Manage License > Load License > Copy License and added the file. Then I restarted Vivado.
HI @tiago0297,
Can you try to create a new project with a TPG and see if you still cannot use the TPG? Also, can you right click on the IP and click show license status (and send a screenshot of what you are getting)?
@florentw
I created another project, but still didn't worked. Tried to right click the IP and search for show license status, but I didn't found that option. I'm using Vivado 2017.4. But I've found some information about the license in Block Propertiens > IP:included.PNG
 Also, I just realized another strange mistake. When I just the IP Block of the TPG, I get the following errors, and some others similar, for the other ports:error.PNG
Hi @tiago0297,
Could you run the command report_environment -file ./report.txt and share the output file?
For the issue you are seeing, I have seen similar issues on windows, make sure you are using a short path. Note that this can also happen because the license is not found.
To find the license status, you need to right click on the IP in the IP catalog list
@florentw
Sure, i'm sending the file.
Thanks, I've found the license status:
Hi @tiago0297,
This is weird... The tools seems to say that you do not have the license but also that you have it... (@anatoli did you already see this?)
Can you try to place the license in another folder (ex: C:\Licenses) and set the XILINXD_LICENSE_FILE field of Vivado License Manager (in manage license search paths page)?
Hello @tiago0297,
Kind Regards,
Anatoli Curran,
It worked! Thanks to everyone who tried to help!
