Video in to AXI Stream Block diagram symbol error
  I would like to report that block diagram symbol for "Video in to AXI Stream" IP has error.
  Input port ACLKEN is shown to be inverted.  But internally it is logic high active.  I am using Vivado 2018.1.
Re: Video in to AXI Stream Block diagram symbol error
Hello wtneo@leica
Yes this is known issue and this will be fixed in upcoming version of VIVADO which is 2018.3.
Meanwhile please refer the product documentation for more information on this.
It has correct information.
Thank you.
Scholar watari
Hi wtneo@leica
Woudl you run "Valid design" first ?
After that, this symbol is changed from inverted to non-inverted.
Best regards,
Hello wtneo@leica
Thank you.
Hi wtneo@leica,
Do you have any updates on this? Are you happy enough with the answer provided?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
