Observer abdelkader
Video interlacing
I am working on a bare metal interlacing architecture. The idea is to load video or image from a TPG or a BRAM, interlace it and save it to a memory or display (in case of using the TPG).
I am developing using vivado 2016.3, and the Artix-7 AC701 evaluation board.
All of your suggessions and questions are welcome.
Thank you in advance
Re: Video interlacing
Hi @abdelkader,
If everything is clear for you on this subject, please kindly mark a reply as solution to close the topic. Else please reply to the topic
Thanks and Regards,
Hi @abdelkader,
My question is: What is your question?
For you information, I tried to write Recommendations for creating a topic in the Video board in the Video Processing and Connectivity board - Resource topic (see part 5 - even if I recommend you to read the full topic). You might want to read them if you want to get more chance to get the answer you need.
Best Regards,
Observer abdelkader
Thank you for the topic proposition, it's very interesting.
My questions are:
1- To develop a video interlacing IP in VHDL, are there a support to follow, for a better design?
2- Do i need, a memory to save video data (pixels) before i start the processing?
3- Is is possible to test the IP using block ram and *.coe file, for a first time?
Take a look at this post.  It has an attachment that shows how to use the VDMA to produce a basic interlaced output from a progressive frame.
Chris
Video Design Hub | Embedded SW Support
Hi @abdelkader,
Thanks and Regards,
