Voyager
Voyager
Vivado 2018.2 replacement SMPTE2022-5/6 Video over IP
Hello I read that SMPTE2022-5/6 Video over IP has been discontinued and is not more present in vivado 2017.2 and later versions. Is there an IP that could replace SMPTE2022-5/6 Video over IP in vivado 2018.2? Thank you.
Tags (2)
Re: Vivado 2018.2 replacement SMPTE2022-5/6 Video over IP
Hi @pierlum,
Please check the Product Discontinuation Notice:
The replacement IP is the IP from Xilinx partner macnica (http://www.macnicatech.com/)
Florent
Hi @pierlum,
Florent
Voyager
Voyager
Hi @florentw,
thank you very much for the reply.
Hi @pierlum,
If the reply was enough for you, please kindly mark it as accepted solution to close the topic.
Thanks and Regards,
Florent
