Observer wadelius
Vivado MIPI ip
Hi, Forum.
I'm about to start a new design and planning to use the Ultrascale+ ZU5 EG or EV.
I have seen a nice dev.kit ZCU104 with an Ultrascale+ ZU7.
My problem is that I want to use the included MIPI ip in Vivado. But those ip's are not compatible.
But they are compatible with ZU3EG, ZU6EG VU3P, KU9P etc
Anyone know why I cant use them with the ZU5?
best regards
Urban Wadelius
Re: Vivado MIPI ip
Hi @wadelius,
All 7-series except spartan-7 are currently supporting MIPI.
Only US+ has the HW for the D-PHY in the MIPI. For 7-series, you are expected you use an external PHY as per xapp894.
Florent
Re: Vivado MIPI ip
Hi @wadelius,
Were did you find this information? As per PG232, I think MIPI is supported on all families starting with 7-series:
Note: There are multiple IPs for MIPI:
  • MIPI DPHY
  • MIPI CSI2 RX Subsystem
  • MIPI CSI2 TX Subsystem
  • MIPI DSI TX
But it should be the same for every MIPI IP
Florent
Observer wadelius
Re: Vivado MIPI ip
Hi Florent,
thanks for quick response.
This information was in the Vivado IP tool, but I saw that I use an old one version 2016.2, and maybe that's obsolete information in that version.
Does all 7-series support MIPI? I thought only the Ultrascale+ had the right hw to support mipi signal levels?
/Urban
Re: Vivado MIPI ip
Hi @wadelius,
Florent
Re: Vivado MIPI ip
Hello @wadelius
@florentw is correct. But I want to add some new information regarding Spartan-7 support.
(D-PHY, CSI-2 TX/RX)
Spartan-7 supported from 2018.1
(DSI TX)
Spartan-7 supported from 2018.3
But I would recommended customer to use US+ device for MIPI since it can support D-PHY electrical spec natively.
Best regards
Leo
Re: Vivado MIPI ip
We Would appreciate your response.
clk_settle User param value in MIPI CSI-2 Tx IP
In MIPI DHPY {Product Guide 202} Default user parameters in 57 page tells only about HS_SETTLE {8:0 HS_SETTLE_NS R/W 135 + 10 UI} and the default value is 145 ns.
On the other hand, the clk_settle as explained in MIPI_D_PHY specification 548 page requires additional clk_settle param to be initiative.
More information on Clk_settle param will be quite helpful. It's not given in MIPI CSI-2 Rx or Tx product guides.
Re: Vivado MIPI ip
Hi @daram123,
This is a different question and this topic was not created by you.
As per the guidelines for the video board:
4. Do not post a question on someone else's topic. Create a new topic if you have an issue. It might not be the same issue
I am closing this topic for new replies. Please create a new topic for your question.
Thank you for you understanding
Florent
